Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-17-2005
panoramical's Avatar
panoramical panoramical is offline
Junior Member
panoramical will become famous soon enough
Getting rid of scratches
Hi,
Do you think I'll be able to get rid of these scratches?
http://www.hanksguitarshop.com/DSC_5159.jpg
If so, how?
thanks
Old 03-17-2005
a27thletter a27thletter is offline
Dedicated Member
a27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond repute
i removed some that were about that bad before. i first used wet 2000 grit sandpaper, then i went over the surface with an orbital polisher and some fine polishing compound, then i went over with some swirl mark remover, and finally went over it with some wax,, . i've been doing stuff like that to cars since i was 17 years old and if someone will trust that to a ferrari i dont see why it wouldnt be safe for a guitars finish, it certainly worked on mine,. you just have to make sure you have a thick enough surface of paint or clearcoat before you start, because this process will remove a fine layer of the top coat,(which is the damaged layer) and it basically just smooths it out and exposes a fresh layer of paint, if you practice the technique a bit you'll be able to make paint as smooth as glass, ..
www.myspace.com/comfortinyesterday
getting rid of silence at the beginning of a song faisdodo2 Fostex Forum 5 11-03-2003 11:38
easiest way to get rid of picking noise? dumass Recording Techniques 8 09-23-2003 12:50
how do i get rid of the clicks on cdr's homerecording Newbies 3 12-18-2001 10:49
How do i get rid of LP scratches ?. timparsons Newbies 0 11-25-2000 16:59
