Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-17-2005
alanfc2 alanfc2 is offline
Newbie
alanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond reputealanfc2 has a reputation beyond repute
Simple question on Low EQ
hi,
this is my biggest problem. Whats been happening is that I think I've killed so much low end on my mixes that everthing sounds shallow and tight. I really got into my own EQ's and had ignored the EQ's done by our engineer, since his seemed too boomy. Now I've gone back to his work and removed my EQ's. Modified them and tried to find the richest but not boomy. Can you take a quick peek at this EQ chart I just painted up, and tell me if I'm way off or not? These sounded a 1000x better to me.. Somewhere I lost my perspective before. I found that with what I have that was tracked, this stops the horrible shallow hard sounds I had.
Previously I had the Bass spiked up at 100 hz and the kick was all gutted out real bad below 300hz ! I knew that the 100hz was "hardness" and the kick was gettin killed, but it was the only way I could make them stand out. Other issues abound but just can you take a look at these?
thanks
http://img.photobucket.com/albums/v4...nfc/CrowEQ.jpg
/edit/
I see how my question may not be so easy to answer
heres' a clue,
the old EQ's that were tight, hard & Shallow
http://img.photobucket.com/albums/v4...fc/CrowEQ2.jpg
The Artist formerly known as ALANFC
Old 03-17-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Nearly an impossible question to answer without posting something for us to hear. Further, what is the scale? Is the bottom line -6dB? -12dB? What? If these are big cuts, I'd question your mic technique since that shouldn't really be necessary.
Like on the kick, a kick mic is designed to provide a bit of boost at 4kHz or so, and depending on proximity will provide a boost or cut at low frequencies. Thus, try moving your mic if you aren't getting the sound you want.
The bass EQ does not make sense to me. Only the lowest fundamentals are 60Hz, like E-Bb. If you want to emphasize low-end, maybe something flatter and wider.
But again, I can't hear the track, so how can I really know?
Finally what is your room like? If you're in an untreated room, I would be wary of making big changes to LF EQ.
Old 03-17-2005
Newbie
OK thanks-
I see now that my question is nearly impossible
I'll try to find the old originals and post !
thanks
Old 03-17-2005
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
Please review your thread titles more carefully!
Old 03-17-2005
Newbie
oops
should have anal-yzed that better
fixing now
grrrh can't change the title!
Old 03-17-2005
LOL...
Not as good as the one that appeared as "guys, you've gotta do me..." (a favor)
Old 03-18-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
try and keep as much lo end as possible without the mix being boomy. This can be quite hard to tell though. Add extra lo end at mastering to control the lo end with multi band compression. This will give a tight lo end without boomyness or lack of lo end.
Million dollar ears.
CRYSTAL MIXING
MY BAND
How do you get the low end out of a mix? atomlow Mixing / Mastering 6 10-16-2002 20:21
mystery low end distortion jdbosshog Cubase User Forum 8 10-01-2001 05:41
Taming the "guitar chugs" low end.... asi9 Mixing / Mastering 2 09-22-2001 02:36
Low end ****update**** Guitaranddrummer Newbies 6 07-02-1999 08:50
Absolute Low end recording- i need HELP!!!! Guitaranddrummer Newbies 2 07-01-1999 12:19
