Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-17-2005
sqwire03 sqwire03 is offline
Newbie
sqwire03 is on a distinguished road
Losing volume on output
Hey I'm new to this site and forum and have a question which hopefully someone can answer. I have Cubase SL 2.2 and I've set up my audio interface and midi interface correctly (I believe). My problem is when I'm monitoring an audio signal to record, the volume is nice and loud and not distorted. But when I play back what I've recorded the volume drops at least by half. I don't know what I'm doing wrong. Even boosting the level does not make it sound like it does when I'm monitoring the sound. Can anybody help with this?
Old 03-17-2005
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
Wow, I never had that happen to me, can you list you specs for your computer
Carter
MCF Productions
Old 03-17-2005
Newbie
I believe my PC is a P4 with 2.8 GHZ, 512 MB, and 160GB.
Old 03-17-2005
Carter's Avatar
Total gear slut
What type of soundcard/intrface are you using?
Carter
MCF Productions
Old 03-17-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
A signal that's being recorded usually goes through a different path than one that's being played back. So to listen to what you've recorded you adjust the volume differently.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 03-17-2005
Newbie
I'm using the M14 audio interface that came with the Cubase System 4 bundle and a 2 x 2 MAudio midi interface.
I'm running my MPC 2000, ASR-10, and SP 1200, sound modules, etc. through a Tascam M1516 16/32 channel mixing board. All the equipment are connected to individual channels and the Alt 3/4 direct inputs of the mixing board. Then I run the direct inputs to my audio interface line inputs. The output is connected from the audio interface to two other channels on the mixing board. I can boost the monitored sound from the inputs and the output volume just fine, but the recorded audio track has a very low volume.
facts about speaker power ratings gusfinley Guitars and Basses 18 01-07-2005 15:49
What is the purpose of the Eurorack's output behaviour? Yasoo Mixing / Mastering 7 01-04-2005 20:58
TA1600 volume controls jrosenstein Other Equipment and Reviews 8 04-28-2003 10:50
Meters vicevursa Cakewalk / Sonar Forum 6 08-10-2002 13:31
