help out with para EQ
hey, couldnt get any help on the cakewalk page so...with the parametric EQ what are standard levels that people use. My main concern is distortion, so at what frequencies and levels (basic standard) should i deffinately be elliminating off my tracks?
cheers, C |
You shouldn't automatically "eliminate" or cut any frequencies. Use your ears to tell you what needs to be done. If you cut your tracks well using good mic selection, technique and level control as well as recording good sounding, well tuned instruments, you might not need to use any eq at all or very little eq. when it comes time to mix.
About the only thing I know for certain I want to do to most of my tracks is to filter out the subsonic junk below 20 hz. Other than that, a cut centered around 500 hz helps out drum kits a lot of the time. |
| Too much proximity, para eq or multiband? | malcolm123 | Mixing / Mastering | 3 | 06-29-2004 14:31 |
| LRBaggs Para DI | Sotonfan | Guitars and Basses | 3 | 02-09-2004 12:19 |
| L.R. Baggs Para Acoustic D.I. | Supersonic | Guitars and Basses | 4 | 05-01-2000 19:33 |
