Do the Seymour Duncan Invader give out alot of hum?
Does it sound distorted on the cleAN CHANNEL? How much hum does it give out with alot of distortion. |
And promptly ripped them out.. Couldn't get a decent sound from it at all.. Switched back to the old faithful EMG81 and lovin it..
Invaders are super high output and have a super big midrange hump right at 1K. They are distorted even through the cleanest amp. They are a 1 trick pony, if you like that sort of thing, good. Use them. If you want a good sound out of your guitar, take them out.
I use invaders in all my guitars, neck and bridge. They are my favorite. No matter the amp you can get great tone no matter the gain setting. I usually have a high gain setting due to playing hard rock/metal music, but if you roll the volume knob back, you can get all kinds of different gain sounds and still maintain the tone.
Ive never had a problem getting a clean sound out of them. Again the advantage is using your volume knob, even on your clean settings. if you have your tone and volume knob cranked along with your amp, then you will get a mild break up of the signal, but if you practice with you volume knob, you will be able to achieve almost any tone you will be looking for. It personally gives me alot of options, without having to change all my settings on my amp. example.....I'm playing songs live by crue,ratt,godsmack, then we go into AC/DC and thin lizzy. I simply leave everything alone except turn my volume knob back half way for ac/dc, then thin lizzy roll it back another 1/4 turn. I still keep tone,and harmonics, but clean the sound up so its not so distorted. all this with my amps gain left at about 75%. I like them because they give me personally alot of options. They will add some gain if you jsut crank them up all the way though. DID i mention, you need to play with your volume knob? hope i helped you in your quest, good luck to you. |
my appologies for not answering all the original questions.
I dont ever experience any hum with my invaders no matter how much gain i dial in. the cool thing is if you need some controled feedback, they will feedback niceley. cheers |
nope...
I've never had any problems with hum from Invaders. But be aware, previous comments are correct: these are HIGH OUTPUT pickups. So if you're like me and never touch the volume knob, you probably won't be able to get a perfectly clean signal out of them. But as for hum, I've never noticed any.
I'd recommend trying a guitar that has them before committing to them - the Blink182 Strat comes to mind.
-] chris [- "For myself, I can only say that I am astonished and somewhat terrified... astonished at the wonderful power you have developed, and terrified at the thought that so much hideous and bad music may be put on record forever." |
I forgot to mention, if you are getting a hum, you have it coil tapped. Make sure the right 2 wires are hooked together when you solder it up. Check the instructions.
| emg vs. seymour duncan? | dumass | Guitars and Basses | 42 | 04-14-2008 16:49 |
| Finally got pics of my studio. | darnold | Studio Building & Display | 121 | 04-08-2005 00:05 |
| Seymour Duncan wiring canundrum... | Aaron Cheney | Guitars and Basses | 6 | 05-11-2004 19:40 |
