questions about eq
the best thing i ever learned about eq was to use less of it, haveing said that.
whare is air? my recordings never seem to have it. no, i wont abuse this knowlege, but i'd like to know. also, i know that mud is usually about 310 or so, occasionally i find myselfe making cuts around 500, and for my money 7k can be problematic on vox. what advice/things have you noticed about eq? whare do you commonly cut? |
The 16kHz+++ region is generally considered "Air". A little high shelf boost at 16kHz can help with that.
Eric Practice Your Mixing Skills! Mix Our Tracks in Your DAW! www.Raw-Tracks.com Online Mixing Forum |
1. Listen for problem areas.
2. Find the problem area by boosting and sweeping. 3. Cut the problem area 1db at a time until it sounds right. Making a habit of always cutting at 310hz is going to leave many of your recordings sounding really thin. Same with 500hz. A lot of power comes from those ranges. |
| 10 questions for the ages | Richard Monroe | Newbies | 27 | 03-14-2005 06:42 |
| questions, questions, questions | chronicinsomnia | Newbies | 8 | 12-08-2004 18:48 |
| Aux Questions | sibleypeck | Mixing / Mastering | 4 | 02-08-2002 17:37 |
| Please try the search before asking questions | ola | Other Equipment and Reviews | 5 | 10-24-2000 02:09 |
