I finally finished the acoustic treatment in my music room!
Hi everybody,
I finally finished installing all the acoustic panels I built in my music room. I built ten 2' by 4' 4" thick bass traps covered in blue canvas. They are made from pine 1" by 6" board cut to size and filled with either 8 pound per cubic foot density mineral wool or approximately 3 to 4 pound per cubic foot density fiberglass. I also built ten 2' by 4' 2" thick panels covered in tan poplin. The frames were made with the same pine board and they were filled with the lighter 3 to 4 pound density fiberglass. The bass traps are all installed in room corners, either wall/wall corners or wall/ceiling corners, spanning the corner to provide better performance due to the extra air space and positioning. The tan two inch panels are installed in the three first reflection points on the side walls and ceiling, in the back of the room and on the side walls in other spots to control flutter echoes. They are all spaced out from the wall two inches to make them effective to lower frequencies. I took the best pictures I could, but I don't have a wide angle lense and the room is only 8' by 11' so there's only so much room to get a good shot. Hopefully you'll be able to get oriented with what you're looking at. The front wall is obvious, but the back wall is the other wall with three bass traps and three tan panels one their sides stacked on top of one another. The wall with the window is to the right of the listening position. The pics more or less take you around the room clockwise. The monitors are set up to form an equilateral triangle with my head, and sit on two inch thick isolation pads I made from 8 pound density mineral wool covered in the blue canvas. My recorder was transferring some vibration (hum) to the table when the drive spun up so I made one for it as well. You should be able to see them in the pics. The listening position is offset to the left side by just over four inches, and the ceiling first reflection panel is offset to match to avoid a skewed bass response at the listening position due to destructive interference. My head is located about a third of the way into the room from the front wall. I would really appreciate knowing what you all think of it, I'm very pleased with how it all turned out. It looks much more professional and clean than I expected, and the color scheme worked out well. Kind of reminds me of a nice car interior. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Cool! How's it sound?
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
insane man !! i've been drawing plans for doing exactly the same thing !!
but i was thinking about GREY and maybe some lightblue, not dark ; héhé but i was never sure how much it would help my room, can u please give us some details on what u can hear? was there a slapback delay in the room before, were there "dead" points where there was no bass (standing waves) i still got these two probs... and was thinking bout building 4 bass traps, one for every corner of my square room... and yeah, tell us some more about the material u used to build these traps, is there a reason why u choosed for that fiber glass and stuff, and not for some sort of special sound insulation stuff? cheers, moi
...listen... |
Sexxxxxxxy!
"See ya on the flip-side" |
Nice, I've been planning to do something similar, but I can't seem to get off my ass.
I wish my lawn was Emo so it'd cut itself. |
When you say "Canvas", do you mean like......REAL canvas
If so, I had to be a bearer of bad news. But CANVAS is waterproof ......which translates into NO TRANSPARANCY!! The weave is SEALED. That means, for broadband absorption, air molecules movement can NOT move through the absorbant material, which is required for it to work. Resistive absorbers do their job by FRICTION of air molecules within the "interstices" or fibers, to transduce the energy into heat. If the fabric is not open weave, then it is a reflective surface. Although, it will allow some low frequencys to enter simply because it is similar to a panel absorber. But then the absorbant material is acting like a dampener. At least thats my understanding. I'm sure it works to some extent, but if it is REAL canvas, you won't get the full benefit of the absorber.My .02 only though. BTW, they LOOK great. Hope it isn't real canvas. fitZ
alright breaks over, back on your heads! |
Awesome job, Riot!
And thanks for all the photos, but can you get a shot or two showing how you hung those traps at odd angles? I'm especially curious about the ones straddling the corners where wall meets wall and the ones straddling the corners where wall meets ceiling. What did you do there? |
The material I used was from a few sources, but if you're looking to build something like this the best stuff is something like Owens Corning 703 or 705, or another fiberglass or mineral wool equivalent. You want semi rigid fiberglass or mineral wool, about 3 to 8 pounds per cubic foot density. And the Owens Corning stuff and many other manufacturers stuff IS designed for sound insulation. Generally, if it's intended to be used for sound treatment, they'll have sound absorption specs for it. |
I just built simple pine frames out of 1" by 6" board, and loaded them with the mineral wool or fiberglass, then covered them in fabric. I actually am co-moderator at Ethan's acoustics forum. I guess I picked things up pretty well, so he asked me to help him run it and field some of the easier questions. I was quite flattered. |
#12
But when I went to describe it, canvas seemed like the closest thing to it. It FEELS sort of like canvas, but it's lighter. It's still tough, but it's not the same. I ran across some real canvas after I started the project and I see what you mean. The real stuff would never work. |
#13
I hung the wall/ceiling traps from a hook in the stud almost at the top of the wall. I put screw in eyelets in the frames about at the midpoint of them lengthwise. I then tied them to the hook from both eyelets using some really cool knots I learned. Cable or wire rope would probably be better, but it would be more expensive and you'd need clamps and all that jazz. I used a bowline to secure to the eyelet in the frame, then ran the rope out approximately to the distance to the hook, then brought it back and looped it through the first eyelet again and tied a knot called a tautline hitch. It's a really cool knot that's a friction hitch. It will hold whatever load you put on it, but you can easily slide the knot up and down the rope and adjust the length. So I did this on both eyelets and that way I could adjust both sides to get it just where I wanted. Worked great, but you have to bear in mind that knots reduce a ropes working load by up to 40%, so get a rope that will easily handle double the weight of the trap. I can find the link to the page where I learned the knots if you want it. Here's a pic of the hanging method of one of my traps. |
#14
Those look very nice (I've been waiting for your response on the "canvas" material before I chipped in anything.
I, too, am contemplating building some panels like these so it is great to see/hear your story. I do have a couple of my own questions as well. 1. For your 4" thick traps, did you use 4" thick 703/mineral wool or is it 2" of insulation and 2" of air space? 2. I can't tell from the pictures but how did you mount your 2" thick units that are 2" off the wall? Thanks for sharing. Darryl..... |
#15
fitZ ![]()
#16
Thanks, Darryl..... |
#17
>1. For your 4" thick traps, did you use 4" thick 703/mineral wool or is it 2" of insulation and 2" of air space?<
Four inches thick mineral wool or fiberglass. You need the mass to absorb low frequencies. >2. I can't tell from the pictures but how did you mount your 2" thick units that are 2" off the wall?< I just used three and a half inch common nails hammered into the frames with two inches sticking out at four points on the frame, then tied rope to the two top nails and hung it on heavy duty picture hangers. They're very lightweight. No prob! ![]() |
#18
A simple way to check for this is to hold up the fabric to your mouth and try to breathe through it. You should be able to with little effort. Most soft fabrics will do well as long as the breath test works. I got my fabrics at Wal Mart, but there's something I should mention. The canvas like material I got was on sale for a dollar a yard and I got almost a whole bolt. But normally it's five bucks a yard! Another thing I should mention that will make the whole process a LOT easier if you do something similar. When you're getting your fabric, try your best to get a 60 inch wide bolt. Most bolts are 36 inches wide, but some, like the canvas like stuff I got, are sixty inches wide. This width works extremely well for 2' by 4' frames four inches thick, because once you've wrapped the fabric around the 2' width of the frame it comes back to your starting point almost perfectly with about an inch to fold over. Trust me, if you can get a 60 inch wide bolt it is totally worth it. The mineral wool I got from a company called McMaster Carr, but if you can find it locally I'd strongly recommend that. I had to pay ridiculous shipping for this stuff. I live in a rural area and couldn't find anything within 200 miles of me, so I had to order it. |
#19
Click on the forums link, and scroll down. It's called "Ethan Winer: Acoustics Forum". |
#20
Thanks!!
Darryl..... |
#21
Thanks for adding the pic that shows how you hung the panels in the corners. One more question, Riot. If you were going to make more traps, would you still use the chicken wire, or do you think that the stapled cloth is enough to keep the mineral wool from falling out? |
#22
#23
i posted over in ethans forum, but i'll ask you a question here to... how much do each of these weigh, and what was your total cost?
also... i wanted to attatch a diagram of my room, but i couldnt on the other forum, so i did it here and maybe you can check it out. i just feel pretty overwhelmed with this whole acoustic treatment thing... my name over on ethans forum is "benjamin james" and my post was called "sound treating my small room"... any advice would be cool.
Mac G5 Dual 1.8GHz Digi 002R PTLE 6.7 |
#24
I spent about $600 total, but that includes a number of screwups, some cheap, some spendy. If I were to do it all again I could probably do it for about $400. |
#25
It simply looks awesome and professional! Good job mate!
How does the room sound now? |
| Bedroom Studio :-O | thepentium | Studio Building & Display | 18 | 12-30-2004 09:16 |
| 6' x 12' control room treatment? | KBlair | Studio Building & Display | 6 | 08-26-2004 00:28 |
| Inexpensive room treatment | Jute | Studio Building & Display | 4 | 05-24-2003 23:10 |
| First Adventure into Room Treatment | Chrisjob | Studio Building & Display | 32 | 05-14-2003 07:40 |
| Ultra-budget acoustic treatment | mgraffeo | Studio Building & Display | 7 | 05-03-2003 12:34 |
