Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-13-2005
pdadda's Avatar
pdadda pdadda is offline
Captain Sea Boots
pdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond repute
Spreading artificial reverb
I have been reading Bob Katz's book "Mastering Audio-The Art and the Science" a lot lately. First off, it is a wonderful book. Here's my question. In chapter 17, he says "One of the first tricks that mix engineers learn is to put reverberation in the opposite channel from the source." How do you do this? I guess its a way for the reverb to not be masked by the transients and "absorbed" into the direct sound. Since I record in a crappy room, I usually add artificial reverb if I need it. Maybe I'm just dumb, but I can't figure out how to isolate just the reverberation and pan that.
Old 03-14-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
To do that, you'd have to have the ability to pan the AUX returns on the mixer...
Old 03-14-2005
Track Rat's Avatar
Total Gear Slut
Or you can return the reverb to an unused channel on the mixer. That way you can pan and equilize the verb return.
Mike
Old 03-14-2005
Thumbs up
yes - or that!
Old 03-14-2005
pdadda's Avatar
Captain Sea Boots
I'm still a bit confused about how to isolate the reverb. I assume you are talking about running a channel to a reverb unit and then returning the outs of that top a separate channel. But won't you just have the original track with reverb applied?
Old 03-14-2005
ragata's Avatar
ragata ragata is offline
dirty punk
ragata is a jewel in the roughragata is a jewel in the roughragata is a jewel in the roughragata is a jewel in the rough
No - setting the 'mix' to 100% WET on the effects unit means that the dry signal is left out of the return.
the passion for destruction is also a creative passion!
Old 03-14-2005
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Most verbs have a mix parameter that controls how much of the original signal is heard with the reverb. You would want to set it at 100% wet.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 03-14-2005
pdadda's Avatar
Captain Sea Boots
Thanks alot folks. For some reason I was thinking 100% wet meant like 1:1 or something. So hence, yes I am retarded. I'll try messing around with it tonight. I am interested in testing out the Haas effect.
The art of Reverb mcmd Mixing / Mastering 9 02-13-2005 08:31
ANWIDA Soft DX Reverb - Group Buy Massimiliano To Other Equipment and Reviews 0 09-23-2004 09:43
Putting reverb on a soundfont Faust Cakewalk / Sonar Forum 1 06-10-2004 08:56
