I'm bummed...
I've been working on my project for over a year. I was new to the home recording thing when I started. I live out in the middle of nowhere so there is no immediate help available, read - objective ears. So I'm basically trying my best to get my songs to sound THEIR best with little knowledge on just how to accomplish that. I just wanted to get them as close as possible so that the ME didn't laugh when he heard my mixes. I did many things to accomplish what I wanted to hear and to get them to sound the way I wanted them to. My confidence in my mixes was at a high and they were starting to sound good to me...
Then a few months ago, I discovered this board. Wow! Tips! Tricks! Pointers! Techniques! Some actual guidance! I started lurking. BAM! Confusion! Compress individual tracks. Don't compress individual tracks. Compress across the bus. Don't compress across the bus. Master it yourself. Send it to a professional ME. (Of course, the best idea) Record effects while tracking. Don't record effects while tracking. If it sounds good to you then it's right! But what if compressing across the bus sounds good to me? Make it sound the best you can at the source. If the source can't be fixed in the mix, re-cut it. Compress only the low end instruments in a bus. etc., etc., etc. Sheesh... I've totally lost all my confidence in my mixes. They sound good to me but they won't to anybody else and the ME will not be able to work with them because of something I did or didn't do. I'm too old for this. Guess it's back to: Welcome to Wal-Mart!
7 Friends don't let friends mix drunk... You can lead a horse to water... but he has to put on his own scuba gear... I'd give my right arm to be ambidextrous... I like the tempo but I don't like the beat. I give it a 6, Dick... |
Have you tried posting in the MP3 clinic? It has helped me SO MUCH.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
It's not as good as a 24 bit master, no. But it will let people help you with what is wrong, and tell you what is right. Helped me far more than any of the other sections of this board.
If it's of any use to you, I always have a compressor across the main outputs of my desk and I never record effects or compression with a track. Best thing is to find an artist similar to the type of music you are composing, listen to the CD in your studio, and if your mixes sound like the CD then you are on the right track!
Stand by for action - we are about to launch Stingray! (Cue irritating bongo music ...) |
![]() What does this mean in your signature? PM me if you need an MP3 hosted for the Mixing Clinic
It means I can host an MP3, so people can download it and listen to it in the mix clinic. You're right - some people in there can be brutal, but others are very helpful. Guess what tho - some of the most brutal people are the most helpful. You will learn a lot about YOUR recordings by posting them. I GUARANTEE there have been worse songs than yours posted. Just do it! ![]()
This is what I know. I used whatever techniques I could to get the sound that I wanted. NOW some of them may be wrong depending on who you talk to. And when it gets to the ME it may cause problems. The only thing I wanted to do in the first place was get my mixes to something that the ME was used to getting. So, since I don't KNOW what an ME is used to getting as far as mix goes, I just made them sound as good as I could to ME. But that could be wrong??? Sheesh... Do you want fries with that?
I'm going to think about it before posting a song. I've just lost so much confidence in what I've done. I'm tempted to just send out all the raw tracks and have them mixed by a pro. But in the back of my mind I keep hearing, "They're OK!"
#12
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid. |
#13
Actually you were very helpful. Thanks much. I've already sharpened it up a bit. But I can't seem to separate the backup vocals and the lead vocal in that overlapping part. The lead vocal just gets lost. There's gotta be a way to fix that. I put some compression on the lead vocal but then I had to bring it up more in the mix. If I bring down the backup's they get lost to quickly. But still, I'm getting somewhere.Thanks!
#14
#15
#16
#17
Thanks for all your help! We'll continue this in a day or so. ![]()
#18
#19
#20
Rather than reply to your MP-3 link, I think it would be perhaps more helpful if kept in the Mixing forum ... as I think this is more of a general mixing suggestion than any specific recommendations about your recording ...
After listening, my initial feeling / suspicion is that your monitors and the room in which you are monitoring are in serious need of help. There are things about your mix that tend to be somewhat typical of mixes done on headphones, home speakers, or even computer speakers. They sound like they were done by someone who can't fully hear what he's doing. My first bit of advice would be not to spend any money on mastering. It would be wasted $$ for the most part. Instead, put that money towards a set of good monitors and some accoustical treatment or design. Spend a lot of time learning your monitors ... listen to all of your favorite records through them; compare them, directly, to your own mixes and truly learn what your stuff sounds like. |
#21
There are two main ideas to keep in your head at all times. 1. Online message boards of audio engineers is not your audience. Take the good and learn from the bad. 2. The ultimate rule is that whatever you're doing to make it sound the way you want it to sound - is right.
It's really easy to get caught up in other people's ideas about equipment and process. It's always great to know what other people are doing, then make a decision whether you're going to follow their ideas. Maybe what one engineer does every session isn't going to work for you most of the time, except for that one time it does. So, keep those ideas in the back of your mind. I've found it very helpful to attempt a mix without any EQ, compression or effects. Just levels and panning. Then, make notes based on what you hear. It's really really easy to throw a compressor (or hundreds of them) on everything and ruin your mix. |
#22
