frequency response
could someone please explain frequenzy response to me, like is 50hz - 150khz better or would be 5hz - 50 khz better? thanks
Gear: soundcraft Mixer m-audio audiophile 24/96 schecter guitars line6 spider amps various soft synths The one plugin that I cant live without:bbe sonic maximizer |
The range of human hearing is 20Hz (low) to 20kHz (high), although most humans can't even hear that full range of frequencies. You'd have to be a dog to hear anything higher than 20,000 Hertz!
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
Meaning - a unit having 5-50Khz that is flat within 1-2dB in that region, will likely be better than a unit having a 5-150Khz ± 10dB.... Also - you have to take specifications with a grain of salt because often, it's the marketing department that publishes them and not the engineering team!
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
im gonna be using the mic for vocals the reason i was asking is i have been looking at pre's and thats the range of frequences i saw.I want to understand the specs b4 i buy one.
actually i was lookign at the behri mic2200
You can safely ignore any references to frequency response in any preamp you buy. If it's a good quality unit, the frequency response will be more than adequate for the job. If it's a low end unit, any claims about frequency response will likely be bullshit.
The frequency range of human hearing, as mentioned above, is considered to be 20Hz to 20,000 Hz at best (measured in young girls), and in most of us is considerably worse. Although there is controversy regarding the sonic effects on human hearing of frequencies outside this range, for practical purposes claims outside this range can be ignored. As in all things audio, you need to listen to the gear to see if you like it - specs can't tell you much of the story.
I'm going through a difficult period - it's called life |
#12
A postmodern theory of audio engineering: Polyvocality of incommensurable mic-positions as a method of Behringer emancipation. |
| Headset with Wide Frequency Response (for Digital Piano P120) | washingtonhtsny | Keyboards and Sound Modules | 7 | 03-13-2005 23:33 |
| Audiophile 2496 Frequency Response Problem | Autist | Digital Recording & Computers | 6 | 03-08-2005 17:29 |
| frequency response | mrbung1e | Digital Recording & Computers | 2 | 06-28-2004 07:48 |
| SM57 & SM58: Difference in frequency response curve! | fiveyearslater | Microphones | 68 | 06-26-2004 14:36 |
| Frequency response question for Harvey Gerst or other audio engineering expert | Kelly Dueck | Microphones | 6 | 06-20-2001 23:01 |
