Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-10-2005
the maestro the maestro is offline
Newbie
the maestro is an unknown quantity at this point
Cool How do I get my finished C.D. to look like the c.d.s you buy at stores?
I want my C.D. cover to look like the industry standard c.d.s how do I go about getting this done. And I'm not talking about a cheap label packet from wal-mart, I'm talking the real deal.
Old 03-10-2005
chadsxe chadsxe is offline
Dedicated Member
chadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond reputechadsxe has a reputation beyond repute
Send it out to get pressed.
Old 03-10-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Supply them with good artwork?
(is this a trick question?)
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-10-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Or just print it yourself. Its easily done. Just get the right paper. Most printers these days should be albe to print fine enough to get a pro look. Use easy CD creator or a similar program to add text and graphics to a CD box template. Only thing is getting the CD printed. You will need a seperate printer for this. Can be piked up pretty cheep vut.
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 03-10-2005
D-ragonS5 D-ragonS5 is offline
Newbie
D-ragonS5 can only hope to improve
there are DVD/CD burners that can actuall inscribe the other side of the cd... but you would need to get a two sided disk, other than that having them professionally reproduced is the only other way.
Dragon S5
DJ @ Club Hoopsters
and on www.earjuice.net
owner - www.shirtpropaganda.com
Old 03-10-2005
livilaNic's Avatar
livilaNic livilaNic is offline
Dedicated Member
livilaNic will become famous soon enough
I would say the same. Good paper and good printer. But if your doing say 100. It would take awhile. Not to print but to put it on the CD itself.
I have an ALPs MD1300 that has micro dry. So its flawless.
Question: Which would you "get it on" with?
A.Model
B.Fat Chick
C.Self
Answer = B
Old 03-10-2005
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
I do a lot of graphics and I have done the artwork for several CDs, including one I recorded in my studio.
Here are some thoughts: Paper labels are bad. They look nice at first, but they peel off the discs and jam CD players, or get put on crooked and make the CD unbalanced, or they get wet or...lots of things happen, all of them bad. The thing I don't like is that it's really difficult to center the label. And it never looks like anything but a pasted-on paper label.
Epson makes printers that will print on ink-jet printable CDs. In other words, you have to buy CDRs that have a blank (usually white) label side that will accept ink-jet ink. I have the Epson R300, which I got for $180US. Basically you prepare the artwork with something like Photoshop and then import it into Epson's software to print the CDs. Epson says to burn the music side first, and that's the way I do it. They do an acceptable job, but it is time-consuming to calibrate the colors so that the CD looks right. For 100 CDRs, the cartridge expense starts to add up. The R300 uses 6 ink cartridges, and I get them for about $11 apiece. It is also time consuming, since you have to feed in each CDR individually. Still, this is my choice when I am burning no more than a few CDRs. The labels don't peel off, and there are no mechanical problems.
The last possibility is having the CDs replicated and printed at a plant. This is the only way you can do it that really works for more than just a few.
The bottom line is, you can get inexpensive, or easy, or good looking, but getting all three attributes without specialized equipment is not really possible. Unless you want to spend a lot of time learning how to do it, and you can do the graphics to an acceptable standard of appearance, and you can buy the printers etc to do it with, it's better to have it done.
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23
Old 03-10-2005
michaelst's Avatar
michaelst michaelst is offline
Dedicated Member
michaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond reputemichaelst has a reputation beyond repute
Design your artwork, master your CD and send it to:
DiskFaktory
It's a lot cheaper than doing it yourself.
Old 03-10-2005
livilaNic's Avatar
Dedicated Member
DiskFaktory
That's kick ass cheap as hell.
A.Model
B.Fat Chick
C.Self
Answer = B
Old 03-10-2005
LRosario's Avatar
LRosario LRosario is offline
Dedicated Member
LRosario is an unknown quantity at this point
Man, this isn't even my area of expertise, but I hear it all the time:
It's usually taken care of through whatever distributor you manage to sign with. But if it's out of your own pocket, then you'd have to find out who does the pressing for that distributor.
However, it's not my area, so I couldn't tell you who to go to.
http://www.cd-rduplicators.co.uk/cdrmedia.htm
Input from Orlando
Lee Rosario
Tracking and Mixing
(C) The Cubian Dreams project (Frankie's first engineering project! I'm proud of him!)
Old 03-10-2005
lpdeluxe's Avatar
A lot of the replication outfits offer graphics designs as well: you tell them what you want, and they make it. I've seen some that look pretty good. Naturally, you pay them to do it.
  #12
Old 03-18-2005
RobertN RobertN is offline
Dedicated Member
RobertN is on a distinguished road
I may be a little late but I can do it.
  #13
Old 03-19-2005
BRIEFCASEMANX's Avatar
BRIEFCASEMANX BRIEFCASEMANX is offline
Winner chicken dinner!
BRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond reputeBRIEFCASEMANX has a reputation beyond repute
my band took blank cds and spray painted the tops! DIYYYYYYYYYY
Has Anyone Tried Uploading Songs To Music Libraries??? weatherbill007 Marketing Your Music / Publicity 103 03-04-2008 13:58
Where do you buy "higher-end" special gear? pisces7378 Digital Recording & Computers 3 07-13-2002 22:39
Need to know good Canadian stores, I want to buy a ribbon mic(can't get em at Steves) Sabith Microphones 7 02-19-2001 23:07
Should I buy a minidisc mixdown deck? Plz help. Dolph Newbies 1 06-23-2000 17:33
