Old 03-10-2005
a27thletter a27thletter is offline
Dedicated Member
a27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond reputea27thletter has a reputation beyond repute
need some advise on turning a room into a recording booth
i have the opourtunity to make a recording booth out of a storage closet in my girlfriends house, the room has wierd dimensions though, its about 5 feet wide by 13 feet long and the ceiling slants down on one side. i'm not concerned about getting the "perfect" sounding room, i just want a space where i can get away from the world and get my ideas recorded. my main question is how to do some sound isolation treatments to the room. what would be some things i could do to the room to help, just at least to muffle the sound thats escaping the room. i'm sure this gets asked everyday and i'm sure all of the hardcore members get tired of hearing it, i'm sorry. ohh, and if it makes any difference, the closet is upstairs , right above the garage, and has no windows, /
www.myspace.com/comfortinyesterday
Old 03-10-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
First, try it and see if it's livable. Maybe you don't really need to treat for isolation.
But you'll certainly need to do something about the acoustics. Read the stuff on Etan Winer's site and his company's site.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 03-10-2005
Dedicated Member
thanks,.. as far as acoustics i can live with imperfection, .. itws mainly just isolation i need, cause i get my inspiration at times when normal people sleep, lol. as long as its muffled on the outside of the room it'll be fine.
Old 03-11-2005
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Not at all. What I get tired of, is people we try to help, who get snotty.
Ok, here is the deal. There is ONLY two ways to increase SOUND TRANSMISSION LOSS. PERIOD. Mass, and decoupled MASS. The best bang for the buck is a TWO LEAF, MASS -AIR- MASS . Same as a regular residential wall. However, the difference between a standard wall, with one layer of drywall for each leaf of mass, and a highly proficient sound isolation wall, is decoupled mass. This means, ONE leaf needs to be decoupled from the framework via a device such as RESILIANT CHANNEL, Risc clips and hatchannel, OR staggered stud construction OR a DOUBLE WALL.
However, this applies not only to the walls, but to the floor and ceiling as well. This implies vigorous and expensive construstion. And it is. In your case, I see two implicit limitations. Its not your space, and it is UPSTAIRS. This is why you can do little to improve the actual mass OR decoupling of the interior leaf. First off, the existing floor acts as a drum head, since it is a membrane itself. This floor, structurally ties to the whole house and there is NOTHING you can do about it except this.
"De-couple" your monitors from the floor!!! Even sitting on a desk, table, or what have you, they will structurally transmit to every connection point in the house. Put your monitors on a couple of layers of mouse pads, or some rigid fiberglass, or some rubber pucks. Something that will absorb the vibration, and keep it from transmitting to the next layer of structure below it.
Same with any guitar amps, or anything that is a source of sound. Decouple it from the floor.
The second thing is HVAC ducts. Are there any HVAC supply or return grills in this space? If so, no doubt they provide a perfect flanking path for sound to other rooms. When recording, or creating sound in this space, cover them with something. Or take the grills off and stuff a small pillow in the ducts. Not the best solution, but hey, what else can ya do Maybe make a framed and hinged trap door that you can fasten over the grills, and open it when you need the HVAC. Be creative
Next, buy a roll of foam weatherstripping and seal the door. TIGHTLY Use good heavy stuff, maybe the rubber strip type with an aluminum backer that has holes for nailing to the door jamb. Airborn sound can leak through the tinyest of holes and cracks. Then get a threshold for the floor. A solid wood one, and one of those rubber strips for the door at the bottom to seal against the threshold.
Another thing for the floor is a throw rug or two if its a wood floor or linoleum. That will help with impact noise from your feet tapping. Ha!
As far a REAL isolation measures, for airborn sound, unless you can add more drywall to the existing drywall, I don't see much you can do in that regard. Maybe replace the existing door, if it is a hollow core. You can find inexpensive SOLID CORE doors at salvage yards. This will help, as doors are the weakest link, and hollow core doors with NO threshold are the worst. The point is this.
Given what you have, you MUST, seal all holes to the best you can. Isolate sound sources from inducing vibration to the structure. And block all flanking paths for airborn noise. Well, thats about all you can do. Good luck. BTW, your slanting ceiling is a good thing, if your monitoring position is placed correctly in relationship to it. It also helps with standing waves between ceiling and floor. As to treatment in the room, your best bet is to spend you next equipment purchase money for Owens Corning 703 Rigid Fiberglass panels instead. It will be a better investment than a new mic!!!
fitZ
alright breaks over, back on your heads!
Old 03-11-2005
apl's Avatar
apl apl is offline
Stand Up Comity
Originally Posted by RICK FITZPATRICK
...seal the door.
Good isolation and good breathing sometimes conflict. The latter is in the long run more important.
My tunes. Thanks!
NB
DA BEARS!
Old 03-11-2005
Dedicated Member
wow, thanks a lot, some very good advice. as far as teh hvac, there arent any vents in the room so thats no worry, , also i did figure that the slanted ceiling would be good for keeping down standing waves. i'm prepared to take any steps necessary except the room inside a room step, just because i dont plan to use the place much more than a year, so no permanent modifications should be made. i do have acess to a plexi-glass enclosure sortof thing, not sure what to call it, they use it in my schools studio to isolate things and cut down on mic bleed. not sure if that would help me at all in this case though, maybe someone could let me know,
size of CR window cmick Studio Building & Display 7 04-12-2007 02:20
mixing complex recording.... ? need yes or no answer a2n3d7y Recording Techniques 4 07-04-2004 10:14
Dead room for a Booth stoctony Studio Building & Display 0 06-24-2004 20:42
The size of the room you are recording in... photoresistor Recording Techniques 6 03-03-2004 07:31
room treatment for recording drums BrettB Recording Techniques 6 09-06-2003 10:44
