Electrical Noise
I bought a new house a few months ago and started building my studio. For some reason I am getting a terrible hum from my amps when I plug in my guitars. (using single coils or humbuckers)
When you kick in the distortion it gets way worse. I have unplugged everything in the room and even turned off all breakers except for one. It still does it! When I first moved in I don't remember them doing this. When I touch the strings, it mostly goes away, so it seems like a grounding problem of sorts. They're building a house next to me, could the temporary power there be affecting me? If I buy a Furman power conditioner, would this fix it? Has anyone else had any problems with dirty and noisy electricity? My last home and smaller studio didn't do this. |
Question: Which would you "get it on" with? A.Model B.Fat Chick C.Self Answer = B Last edited by livilaNic; 03-10-2005 at 07:11.. |
Do you have a computer next to you? The monitor throws out a lot of interference. You may have some kind of ground problem too. Plug everything into the same outlet. I once got a terrible hum from plugging to connected pieces of equipment into different outlets in the same room. Really surprised me. Plugging them into the same power strip fixed it.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
All of my non-midi guitars and basses have been converted to balanced audio, using 1/4" TRS jacks.
Since this is for studio only, this doesn't present me with a "use house amps" on stage or elsewhere, type problems. I was able to do this because my instruments have active electronics, so it was a matter of replacing the pre-amp circuitry with homemade stuff that captures the pickup signals and balances it right away internally, passing it out that way to whatever is down the line. My amps now have balanced inputs also. However, this means I cannot use foot pedals or things along those lines. I have to insert them into the amp's sidechain, and I get mixed results depending on what each foot pedal is. |
make sure there is not a dimmer on your light switches.
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen |
buy a power sstrip with RF filtering, electricity in some houses can be really dirty. That's the cheapest solution. Nest step up is a power conditioner, then hunt the bad earth.
Fun and games, eh? |
| Desperate for help with reducing noise and improving quality!! | Nemesis | Recording Techniques | 16 | 01-04-2005 05:58 |
| Echo Mia, Sonar noise issues | MrStitch | Cakewalk / Sonar Forum | 15 | 04-27-2003 16:00 |
| Reamping. Noise noise noise! | Uladine | Recording Techniques | 9 | 03-18-2003 14:35 |
| white noise? noise generators?(analog synths) | electronicdreaming | Keyboards and Sound Modules | 7 | 02-15-2002 13:29 |
