Cubase LE or
I was thinking about buying the Firepod and getting the LE version of Cubase, or buying a different interface (thought about the MOTU HD) and buying the full version of Cubase SX. What would I be missing with the LE? Just getting started with this digital recording and gonna build a computer aournd what i buy. do you guys suggest either or another?
I am planning on recording my metal band and eventually moving on to all music styles recording. |
it goes Cubase LE Cubase SE Cubase SL, 1,2 OR 3 Cubase SX, 1,2 OR 3 Hope that helps
Carter MCF Productions |
What do you mean I won't miss a thing? I will get all the features of SX if I buy the Firepod and get the LE version? Can LE be upgraded to SX?
I'd use ntracks.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
and yes you can upgrade to SX from LE. Hope that helps out!
LE and/or SE (they are the same thing) has about 80% of the features of the full-blown version. There are charts on the steinberg site comparing the versions.
You can upgrade but it comes out to the same as buying SX from a discount mail-order anyway... you won't save any money. I switched over to SE while going through some NTrack 3-to-4upgrade teething problems (mostly solved now; it's also a great recording program) and you can't go wrong with starting out with SE/LE. |
LE isn't SE
LE is actually a lighter version than SE -- check out this chart for comparisons. I use LE and it's been fine, but I will definitely be upgrading. LE only comes with 2 inserts and 4 sends per channel and it's limiting sometimes. http://www.steinberg.net/WebVideo/cubasesystem4/English(UK)/doc/Cubase%20Syste Keith |
I just got my Firebox last weekend and I recorded a song using Cubase LE. Compared to SX I think sound wise it isn't any different. I have used a not so legal version of SX which has been wiped away from my computer so I am aware of what features are not in the LE version. I missed the extended mixer views, the additional plugins, and the amount of effects per channel but I don't miss the guilt. There are plenty of good free plugins that will make up for what's missing.
I will gladly use my limited but legal copy of LE in place of a bootleg SX. I most likely will upgrade within a year but LE seems to do the job just fine for what I record.
I lost my pants in the fountain. |
Thank you for clarifing that, I posted it earlier in this thread. Heres a better link for the comparison.. http://www.steinberg.net/displaydoc_...id=&loc=doc181
| Non-newbie Cubase SX sync issues | Taufactor | Cubase User Forum | 2 | 08-04-2004 14:24 |
| Building a computer specifically for Cubase from scratch | anppilot1 | Cubase User Forum | 2 | 10-02-2003 23:42 |
| Argh! Reason & Cubase sync problem. | trogdor | Digital Recording & Computers | 1 | 09-20-2003 11:08 |
| Cubase SX - problem with SF DirectX plugins | MBP2112 | Mixing / Mastering | 1 | 09-11-2003 05:28 |
| Using SF DirectX plugins in Cubase SX | MBP2112 | Cubase User Forum | 0 | 09-11-2003 00:03 |
