Old 06-20-2000
Randy5235's Avatar
Randy5235 Randy5235 is offline
Senior Member
Randy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant futureRandy5235 has a brilliant future
Wink
heres the problem,I live in an apartment,thats it really,and oh yeah all i have are tube amps(not that,that is really a problem elsewise),any ideas for recording a good tone?cant get loud enough to even really get the good tone out of the amps,let alone get a good signal/noise ratio on mic,tried running out the line out on the amp,crappy sound all the way maybe i could build a small (not that small i guess)box to hold my cabinet so I could crank it?any other ideas?,im open ,thanks
Old 06-20-2000
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
Wink
1 Get a Pod.
2 Shift the amp into the closet, line it with sleeping bags, foam and dead bodies. After 7 mic placement experiments, record the track.
Now, which one is easier?
Old 06-20-2000
Kelly Holdridge's Avatar
Kelly Holdridge Kelly Holdridge is offline
1K Silver Member
Kelly Holdridge is on a distinguished road
Wink
Have you considered disconnecting the wires from the speaker and running them through resistance first? This will help your "out of the tube sound," but it won't be the same as when you crank up your amp w/ normal speaker levels. If that doesn't work, try the POD. I think you can get the new version for $299.
Old 06-20-2000
Track Rat's Avatar
Total Gear Slut
Wink
Kelly, I think you're refering to a power soak. You can get the tubes to light up but that's only half of the problem. The guitar won't "light up" and then there's the speaker distortion that only occurs when you're driving the system hard. Maybe a Sansamp or the mighty pod is the only answer if you're in an apartment.
Old 06-20-2000
KingNothing's Avatar
KingNothing KingNothing is offline
Force of Nature
KingNothing is on a distinguished road
Wink
Get a Marshall Power Break or whatever its called.
Old 06-20-2000
Mountaineer Mountaineer is offline
Dedicated Member
Mountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant futureMountaineer has a brilliant future
Thumbs up
Track Rats Right. Get on Ebay and search for a Tom Schultz ( Boston ) power soak. They go used for $75 - $100 and will let you use all the tube power at low volumes. They are installed between the amp and the speakers.
PAPicker
Old 06-20-2000
virtual.ray virtual.ray is offline
Force of Nature
virtual.ray is on a distinguished road
Wink
I've never used this type of device,but I've heard that they wear out your power tubes faster than normal operation.There's a guy who makes a 5 or 6 watt tube amp with a speaker for just such an application.Sirry I can't remember his name,he had an ad on Harmony Central.com a couple of months ago.The Idea is to have the sound of the whole chain,preamp,power tubes,output trans,and speaker overdriving w/o getting evicted.
Old 06-21-2000
BigKahuna BigKahuna is offline
Force of Nature
BigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond repute
Wink
I'd take a POD over one of those attenuators any day. Give it a listen at least. You may want it in your rig even when you can play your amp loud.
Old 06-23-2000
joeguitar joeguitar is offline
Newbie
joeguitar is on a distinguished road
Wink
Yeah, POD rawkes! I also have a DC-30 and I can get great tracks from POD easier than setting up and "hopefully" getting a good mic placement. It helps to keep using the tube stuff on gig's and band rehearsal to keep your ear trained for "tweaking" the POD but for recording, it's great!
Also, you can record "clean" tracks while monitoring only a decent POD tone. Run the "clean" guitar back into POD during final mix and really tweak the POD and effects to the vocal. Very cool!
Sometimes I run the the same clean guitar signal back through the POD several times with different amp settings and get a massive "layered" sound! Just like Keith Richards running into a Bassman, Marshall, Vox etc. at the same time! (o:
Cheers, joe
