Old 06-18-2000
ericbonn ericbonn is offline
Newbie
ericbonn is on a distinguished road
Wink
i know that they are for routing but how? i really dont understand the concept. also balanced and unbalanced. can someone explain in real world terms?/ if i got a mic with a 1/4 inch plug on the end will it make a difference if i put an extension on it with a xlr on the end?
Old 06-18-2000
Nilbog's Avatar
Nilbog Nilbog is offline
hello
Nilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond repute
Wink
To my understanding, a patchbay is for orginazation. You plug everything into the back, and label the front accordingly. That way you have one place to plug everything in, and it's all together. I think I'm gonna buy one soon, because i hate reaching around behind all my stuff every time I need to plug something in.
The best way to go 1/4" to XLR is just as you described. I was told that those expensive transformers add color to the sound.
-Nilbog
Old 06-19-2000
Cakey2 Cakey2 is offline
Senior Member
Cakey2 is on a distinguished road
Wink
Right, i'm, gonna have a go at a simple explanation of a patchbay. With pictures.
,,,,,, jack1,,,,,, jack1
,this ---------/---------
,,,,is ---------/---------
the,,,,,,,,,,,,,, /
back ---------/---------
,,,,,, jack 2,,,,,, jack2
Just ignore the,,,, I've used them to make the diagram line up.
Now, if you imagine the pairs of dashed lines as jack sockets and the line of /s as a circuitboard thingy, then we'll be ok.
How it works,is, if your plug an out put, say from your multitrack (or soundcard) into the back jack 1, it'll come out automatically at back jack 2. This is called 'normalled' patching - you plug into rear jack 2 the thing that you would normally connect point-to-point to the multitrack output, eg a mixer input. Gottit?
Now, if you plug something into front jack 1, you will get the same signal again ie a listen-in - effectively you have a split signal. However, if you plug something into front jack 2, then you switch off the rear input from back jack 1! So you only hear the signal you've 'patched in' eg on the mixer. Clever, eh? But there's more. Image we have lots of these patch units, side by side. When you plug all the inputs and outputs from all your kit into the patch units, you can rout anything to anywhere with a little jack lead, patched from any front jack one to any other front jack two! You can listen in to any output sigan at any stage in the signal path!
I'm not sure this makes sense, but I dun my best.
Oh, I think I've actually described a half-normalled patchbay. Ask if you need to know what the other types are and what they do. And anyone should feel free to correct what I've said wrong.
Patchbays are a godsend, but you do need a _lot_ of cable.
G'luck,
matt
[This message has been edited by Cakey2 (edited 06-19-2000).]
Huh, diagrams are hard.
Old 06-19-2000
hixmix's Avatar
hixmix hixmix is offline
Halibut, North Dakota
hixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond reputehixmix has a reputation beyond repute
Wink
I love patchbays. I can reconfigure the signal path of all the components in my studio in seconds.
Basically it puts all the ins and outs of your components up front and at your fingertips.
[This message has been edited by hixmix (edited 06-19-2000).]
Old 06-19-2000
Guest
Posts: n/a
Cool
Testing. Glad to know what the Bay of Patches really means.
GH
Old 06-20-2000
CJWalker CJWalker is offline
Dedicated Member
CJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond repute
Wink
PATCHBAY = LIFESAVER
Any Questions???
