Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-03-2005
11miles 11miles is offline
Senior Member
11miles will become famous soon enough
To record midi output from Groove Agent, How to?
I read even that it's impossible?
How is that?
I use it primarily for sounds. I draw my own midi! I've used it so for about a year!
But it seems that my tracks are a bit dull, and i want to spice them up with some fills ando so.
I would like the midi output to be recorded not audio, so i can twist the eq knobs some more.
So what's up with this?
I thought i would draw the drums track as i saw them right and then recorded some fills straight form the GA, and just put them in the right place.
Tell me more, please
Old 03-04-2005
mulch mulch is offline
Newbie
mulch is on a distinguished road
Not sure if this is the answer you are looking for but,
For SX
Set up a midi channel with midi chnl 10 and select GA as the output. Open GA from the e button. In GA click on the setup cover thing, and switch the midi out to the right. Go back to your tracks screen w/o closing GA (make sure you can see GA behind your tracks window). Change GA from output to input on your track. Arm it and monitor it. Flip back over to GA, and record.
This is for controlling GA in 'real-time' as you record.
If you were looking on how to record and export a midi file from GA, I don't know how yet...
-mulch
MIDI guru needed elect drums soundfonts wfaraoni MIDI Mania 9 06-19-2006 10:36
Cubase SX / Groove Agent Midi Output Problem joeSciacca.com Cubase User Forum 6 08-12-2004 13:41
can't select midi output in HS02 Kemmrich Cakewalk / Sonar Forum 5 10-17-2002 04:28
Can't record MIDI although I'm doing everything right? Oysterman MIDI Mania 7 01-29-2002 17:01
new studio need help.. fast!! Readytodothis Newbies 8 04-06-2000 01:55
