if i was to buy a small mobile home would that be a better then trying to build a building?
then all i have to do would be to put down the sound stuff on the wall's and floor. do you think this is wroth buying or should i just build me a building? i would love to have somthing that i could move my self by a truck just in case if i was to move again. |
I suppose, but that might get pricey. First it would be very hard of impossible to soundproof it, and second, you would have to run all of your electricity to it somehow.
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen |
thanks notbradsohner,
i guess i couldn't go with a school bus then could i? well i guess i'll build a building then, you know of any really good lay out's of some studios? if any body does could you all send me some. i dont need anything really big maybe a "12*20" building would be nice. my bothers own there own saw-mil and i can get any kind of wood i wont and my bother said a building this big would run around $5000.00 for every thing so maybe some way i'll get the money and do that. any of my bothers can do the electricity for me so thats rally good for me and for my wallet ![]() |
I happen to know of a pretty well respected recording studio in a doublewide mobile home.
SoMm |
do you know how they did it?
i mean like what kind of stuff they used to sound proof it? i really need some help with this cuase i dont know the first thing about sound proofing. could any one help? |
Start here.
http://www.soundproofing.org/index.html Read read read. Do searches in google for soundproofing techniques and you'll find out more. Here's another bit of info http://doityourself.com/wall/soundproofing.htm It's a learning experience and it will cost you some cash, but the benefits are very nice. I can play amplified music with my trio at 10 pm WITH a trap drummer and the neighbors don't hear it. ![]()
...if it grooves, record it! |
hey thanks for the help guys, or girls.
ill go and read it ![]() |
hey could any one like give me a shopping list so i know what to buy
like all the stuff i need to sound proof a 12*20 room. 'cuase as i said i dont know any thing about sound proofing. as in all the walls and the floors and do you know about what is a really good kind of door to use? |
Ummmm....thirteen minutes is probably not enough time to learn all there is to know about building and soundproofing a studio.
Give it some time....or budget some professional assistance. There's no way somebody can just instantly transfer the knowledge that they've spent years attaining directly into your head. I know it's hard to be patient..... ![]()
Whyseye Sight |
Even then, he doesn't manufacture Tyvec, concrete, rebar, roofing materials, exterior shiething, insulation etc. etc. Even a small building uses an abundance of different materials, ALL of which must be available to you if we were to spec them for you. For instance, we have no idea of the soil conditions which determines your footing design as well as roof loads which also has a bearing. You could build post and beam construction, but then point loads on footings would have to be calculated. Standard residenctial construction in the US STILL has a variety of material choices and this is only the exterior shell. But just for the sake of ILLUSTRATION ONLY, here is a small list. Exterior SHELL. 12 x 20 Foundation Footing..8"wx18"d concrete w/ integral 4"slab w/ embedded wire screen over visqueen layer over 6" gravel bed (assuming min acceptable soil standards exist) Exterior wall framing. 2x6x10 DougFir stud/plates studs @ 16"oc Exterior sheithing......1/2" OSB w/ 1" Stucco Insulation Rockwool or Fiberglass batt R-38 Roof framing ... Standard Sissor truss @ 16" o.c. Ext. pitch 5/12 int pitch 3/12(note attic to be vented, roof not part of 2 leaf STL system Interior control room sheithing...2 layers 5/8"drywall on Resiliant channel(fastened to ext. framing except for iso wall @cr/studio(double wall w/ same drywall schedule Control room floor synomonous w/ slab) Control Room ceiling 1st leaf (2 layer drywall on underside of truss w suspended 2nd leaf via Risc isolators and Hatchannel w/ 2layers 5/8" drywall (4 layers of drywall MUST be in truss calc's) Studio ceiling .. 1st leaf 2 layers 5/8" drywall on underside of truss- 2nd leaf ..2 layers 5/8" drywall on 2x10(see structural span code) ceiling joists supported by wall framing on floated floor. Studio walls. 2x4 framed on floating floor w 9" airgap from interior sheithing to exterior sheithing. Interior shieth w/ 2 layers 5/8" drywall. R-19 batt type insulation @ wall cavities. Doors/jambs....(2)1 3/4" Solidcore ext drs w/ vesibule airlock Provide seals/thresholds and custom Jambs @ RC walls w/ floating trim. Interior ..Double sliding glass w/ special flush floor channels, smoke seals and 1/4" glass w/ angled airgap min 8" at short end. Trim and baseboards TBD by room construction and iso connection requirements. HVAC..double duty plenum w/exterior compressor(spec'd by professional) serpentine flex ducting, with decoupled brackets, grills, registers etc. Interior Acoustics..prior design integral w/ room designs..(ha!) ie..lots of OC 703 or Rockwool panels w/ deep bass traps into ceilings. Attic insulation...full roof framing cavity R-38, 18" blow in or batt type at cieling, and R-19 @ airgaps Roof shiething..5/8 OSB w/ high profile comp 25 yr roof over 30yr felt. Gutters, eaves, venting, etc as per preference. Electrical plan as per requirement and code PERIOD!! Note, all construction connections, materials spans etc must be approved by local permit issuing authority. Well, as you can see, this BARELY scratches the surface of specifying things from a distance. In reality, it would be rediculous for anyone here to ACTUALLY try to do it as they would be putting themself in a precarious position as it is not within the scope of a forum such as this to do so. My little spec list here was for ILLUSTRATION ONLY. DO NOT USE FOR ACTUAL CONSTRUCTION !!! (Note to Rod/Steve. You KNOW where I'm coming from!!! I am NOT delusional )fitZ ![]()
alright breaks over, back on your heads! |
hey rick fitzpatrick,
thanks for all that. i have no building code here, i'm in valley head A.L and live in the country. but i'm clost to fort panye A.L and no i have not check the ground but right in the back yard were i live my bother built his big work shop and it stands real good. my father owns the house and the land i'm liveing at. my bothers seals just plan wood i could use it for the framing right? i need good stuff but i dont have that much money yet. but i'm saving. i know it's going to be a lot of money. does this tell you anything? |
#12
SoMm You can't scare me! |
#13
fitZ Quote:
I don't know what plan wood is? Let alone what you mean by "seals". Sealant comes in various products and types. If you mean pressure treated, it would depend on where its used. If it means "primed", again, it would depend. And does this tell me anything? No. Sorry. fitZ
#14
Nothin' like a puzzle.
Whyseye Sight |
#15
Give me a break......I already gave them a lesson.fitZ
#16
Was a high wall there that tried to stop me Sign was painted, said, "Private Property" But on the back side it didn't say nothing This land was made for you and me - WG |
#17
.....for now....
Whyseye Sight |
#18
Voila! Studio!
I think he is looking for a simple answer............for which there is none; however, I think he should build a pole-barn, buy used office cubicles, surround his mix desk with "foam-by-mail" acoustic foam and get a RadioShack mic and.....................
Voila! Studio!
"See ya on the flip-side" |
#19
thanks for all the help,
i think im going to read up and build from the ground up. i have this great book on it. just got it on the web. maybe i'll be back here to ask some more "Qs" but as for Rick he'll be blocked from writing me. dont need any of his mouth right now. thank,.. ![]() |
#20
#21
In all the time i've been browsing this site, i've only seen the use of a mobile home suggested as a studio by one other person. It was Zeke Sayers , any of you older members will remember him and know why im laughing my ass off right now. Oddly enough Zeke had a spelling problem too, perharps they are related?
#22
Dont stress it Rick. If he wants to be an ass like that, then he certainly wont get any help from me and hoperfully not from anyone else around here. I hope he knows that.
#23
Call it Partridge Family studios.. Don't come to us, we will come to you...
#24
Gee, Good Job! Cletus.
Question: Which would you "get it on" with? A.Model B.Fat Chick C.Self Answer = B |
#25
Whyseye Sight |
| Maybe you should read this | noisedude | Microphones | 94 | 12-29-2003 14:42 |
| N-tracks vs. Cakewalk Home Studio | Ricklh | Digital Recording & Computers | 10 | 11-10-2002 16:38 |
| Home Recording Startup | dustinself | Digital Recording & Computers | 12 | 09-13-2002 13:15 |
| Where do you buy "higher-end" special gear? | pisces7378 | Digital Recording & Computers | 3 | 07-13-2002 22:39 |
| Setting Up A Home Studio DAW | OnceNeverRead | Digital Recording & Computers | 1 | 06-28-2002 18:43 |
