Old 02-26-2005
Newbie-Doo's Avatar
Newbie-Doo Newbie-Doo is offline
Dedicated Member
Newbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond reputeNewbie-Doo has a reputation beyond repute
Exporting DAW Files to Sonar 2
My music minister at church borrowed a Yamaha AW4416 to do some recording and has to give it back in a couple of days.
We got all of the tracks recorded but the final mix needs more work so we want to export the tracks to Sonar so we can take our time.
My sound card is a Gina20. It only has SPDIF in/out and 2 Analog Inputs.
How can I get all 14-16 tracks moved over without messing up the timing?
Thanks!
The cure for GAS? Unemployment.
Old 02-27-2005
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
Manually, track by track and then line them up.
<insert something witty here>
Old 02-27-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Is it possible to still put a percussion hit on all the tracks? You can use that to do the alignment after you've moved them over.
Old 02-27-2005
Porter's Avatar
Porter Porter is offline
aka WookieMan
Porter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud of
Doesn't that unit have a CD burner in it?
Can you burn wav files of each track individually then import into Sonar?
Just a thought..
Porter
Old 02-27-2005
Newbie-Doo's Avatar
Dedicated Member
Just a thought..
Porter
Yes, it does have a burner. But man...that would be a lot of CDs. I think it would be faster to use the digital in/out if I can figure out how to do it. And I shouldn't lose any signal quality that way, right?
Old 02-27-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
You shouold easily be able to transfer a stereo track at a time across spdif. Get a spdif audio cable from GC or wherever, and connect it from the Yammie's spdif out to the spdif input of the Gina.
SPDIF is steros, so you can transfer two tracks at a time. Make the Yammie your digital master, and away you go.
Because it is digital, you won't lose any quality.
The fact that no one understands you doesn't mean you're an artist...
Old 02-28-2005
Newbie-Doo's Avatar
Dedicated Member
Cool! I'll let you know how that works out.
Thanks for your help!
Old 03-01-2005
Newbie-Doo's Avatar
Dedicated Member
Tried the Digital in/out and hard pan left and right for two track recording, and that looks like it is going to do the trick.
Now I am just running into a little stuttering. When I turned off all the input/output drivers except the digital in and out, that seemed to help. I would like to get the bit rate and depth up as high as possible so any recommendations on bit settings or driver type to use would be appreciated.
Thanks to everyone for your advice.
Old 03-01-2005
Porter's Avatar
aka WookieMan
Are you using only one sound card? I had something similar when i was recording on one card and listening to play back on another.. if you can, only use one card, or if you have to use 2, make sure you can sync them together.
Just a thought..
Porter
Old 03-01-2005
Newbie-Doo's Avatar
Dedicated Member
I have two cards. A Gina20 and a Soundblaster Live, but I'm only using the gina for recording.
Old 03-02-2005
Strryder Strryder is offline
Force of Nature
Strryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond reputeStrryder has a reputation beyond repute
If you are using spdif for the transfer I think you should set the sample rate and bit depth for the project the same as what the Yammie has the data recorded at, if it's 16/44.1, then that's what I would use, I might be wrong, but I think that an incoming digital signal would overide whatever settings you've put on the card or setup in Sonar, and possibly cause problems if they are not the same.
  #12
Old 03-07-2005
Newbie-Doo's Avatar
Dedicated Member
I changed the driver in Sonar to ASIO and that allowed me to record via the spdif at 24bit/44.1.
I didn't lose any sound quality, but I couldn't figure out how the to sync the tracks. I was getting a sync error on the DAW unit, but with no idea what I was doing I just had to be happy that I was able to record all the tracks before giving it back.
Now all i have to do is find the easiest way to sync up the tracks again and I'll be in business!
exporting cubase sx files to pro tools? dune5233 Cubase User Forum 2 05-11-2003 04:47
Can't burn Sonar projects with new DAW? devilboy Cakewalk / Sonar Forum 2 04-24-2003 16:16
Exporting MIDI files in Logic glamslam MIDI Mania 1 01-24-2003 17:34
Exporting Wav Files in Sonor 1.0 Ismellelephant Cakewalk / Sonar Forum 3 06-21-2002 17:42
Exporting Audio in Sonar Question NobleSavage Cakewalk / Sonar Forum 3 11-19-2001 09:07
