Old 02-24-2005
sax_fan sax_fan is offline
Newbie
sax_fan is a splendid one to beholdsax_fan is a splendid one to beholdsax_fan is a splendid one to beholdsax_fan is a splendid one to beholdsax_fan is a splendid one to beholdsax_fan is a splendid one to behold
Mixer setup help
I bought a Yamaha MG 10/2 and still have some time to assess before deciding whether I should return it and get a 4 Bus or something else instead. The goal is to record my sax along with some midi stuff.
As I'm new to the whole mixing thing, can someone tell me how to monitor with headphones through the mixer previously recorded midi and audio while laying down a new track. I know it's easier with a 4 Bus.
The equipment I have to hook up are a condenser mic, a synth, a keyboard controller (hooked up by USB), an external sound module and an audigy 2 soundcard (I know... it's on the list to be replaced). I also have an Alesis nanoverb Currently I don't have the synth hooked up and I am not using the nanoverb. I am running the mic into Channel 1 (XLR), the sound module is hooked up to channel 2 in stereo. The Stereo Outs are hooked up with an adapter into the line in of the audigy card and the output of the audigy is hooked to the "tape in" of the mixer. It works (sort of) but I have 2 problems: (1) I have to keep the volume of the "tape in" down or I get feedback (not really sure if this is going to be a problem) and (2) when I monitor previously recorded midi tracks while recording audio, all of the previous recorded stuff is recorded as audio on the new track (this IS a problem).
Any thoughts? Should I just exchange the mixer for a 4 bus? Is something other than a mixer a better idea? Please try to be simple (i.e., not too technical) in your response/explanation, I am just getting the hang of this.
Thanks.
Old 03-08-2005
vod vod is offline
Newbie
vod is on a distinguished road
I'm having the same problem with a UB1204 mixer and an Alesis nanosynth. Whenever I try to listen to what I've recorded into the computer and lay down a new audio track the sound from the nanosynth gets recorded. The nanosynth runs into channels 3 and 4 on the mixer so that I can hear everything from sound card and nanosynth through the same speakers. I hope someone has a fix for this problem.
Vod
Old 03-08-2005
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
dont connect from the sound card to the tape in. doing this sends that audio back through your mixers main outs and back to your soundcard. Instead, connect the out from the sound card to one of your unused channels of the mixer and keep the fader on that channel all the way down so it doesnt make it to your main outs and you can monitor from your Control Room out or your headphones out. Let us know if this helps...
Jeremy
Old 03-09-2005
vod vod is offline
Newbie
I'm kinda stepping on Sax fan's post, but moving sound card outs to channel 4 and recording another audio track still picked up previously recorded sounds. I'll start my own thread and explain my set up with more detail.
Thanks
Dave
Old 03-09-2005
thajeremy's Avatar
registered abuser
this problem is quite common and your answer is probably in here...
http://homerecording.com/bbs/showthread.php?t=117692
Old 03-09-2005
estring estring is offline
Junior Member
estring is on a distinguished road
Vod
You shouldnt be having this problem with the 1204.
Connect your Alt 3/4 outs to your soundcard ins. Then your SC outs to any available channels on your mixer. Then press the Alt3/4 button on the channel you want to send to your soundcard. You can monitor the whole mix but only the channel with the Alt 3/4 button pressed will be recorded.
Old 03-10-2005
Newbie
Vod,
no problem "stepping on my post." I'm actually glad you posted, because my post wasn't getting any responses.
I decided to return the Yammie and I got a Mackie 1202 vlz pro instead. I like the mixer, but I've got a ton to learn. Did you get your issue straightened out?
Old 03-10-2005
vod vod is offline
Newbie
No, still working on it. I started a new thread titled - connect mixer and computer. We're getting closer. I know it's going to come down to the audio outs from the Nanosynth. Stay tuned.
Old 03-23-2005
vod vod is offline
Newbie
Sax Fan,
Check out my thread "connect mixer to computer". There are some great ideas there for our mutual delima.
Vod
Old 03-23-2005
Newbie
Vod,
Thanks, will do. I think I finally got my situation worked out. I don't completely understand the "why," but I'm getting it to do what I want for now, so that's got to be a good thing.
The more I play and read, the more I learn.
Motif to Behringer mixer setup? boy2man86 Keyboards and Sound Modules 3 11-13-2004 21:25
Computer Setup w/ Delta 66 and Mackie mixer Jnnyquest Newbies 5 07-29-2004 14:56
Computer/ external mixer setup mroach23 Digital Recording & Computers 9 03-23-2003 22:43
delta 44 and mixer setup guitar9 Digital Recording & Computers 1 11-23-2001 10:20
Computers, MIDI, sound card, mixer, -- I have questions on studio setup -- PLEZ HELP! kwes43 Digital Recording & Computers 4 11-12-2001 21:10
