What this + sign means in SONAR?
I have noticed that I have a + sign in one of my projects. You can see it in the track view along the volume and pan controls. I´m not so sure but I think it's telling me that I have some kind of automation, that´s why if I set the volume to -4 or pan the track 45% L when I open SONAR again everything is back to zero. Do you know why this happens and how can I get rid of it??.
Thanks TS |
It means you are in offset mode. The + sign means that you are adding (or subtracting) that much volume from whatever the "actual" volume setting is.
To get rid of it you need to toggle out of offset mode. ![]() Actually, I think the location is different depending on which version of Sonar you are using. In Sonar 4, go to the icons at the top of Track View and hover over them until you find the Envelope Tool. Then click the down arrow next to the icon and uncheck offset mode. BTW, you probably want to make sure everything is set to 0 before you toggle out of offset mode. |
Thanks I´ll check for that icon when I get home.
TS |
| Sonar 4.......some questions | Magnum | Cakewalk / Sonar Forum | 25 | 07-15-2006 11:27 |
| Q80 to Sonar = bad midi transfer | Lostinspice | Cakewalk / Sonar Forum | 8 | 08-05-2003 07:12 |
| Delta and the newer Sonar version... | Still' Dreamin' | Cakewalk / Sonar Forum | 32 | 02-13-2003 23:31 |
| Just an idea for Sonar.... | Still' Dreamin' | Cakewalk / Sonar Forum | 10 | 08-14-2002 16:11 |
| How to : Sonar midi -> wav (I have a sound card) | cowby | Cakewalk / Sonar Forum | 1 | 07-29-2002 08:15 |
