Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 02-21-2005
rdfuze rdfuze is offline
Newbie
rdfuze is an unknown quantity at this point
Garbage can snare
Hey can anyone help me tame my snare drum that sounds really garbage can like when im recording it , its a ludwig set im using an sm57 on the snare and two u87s on the overheads as well as an sm58 on the hat. Im trying to get it to sound a little more solid. with some bottom. Is it the size snare im using. Im in a medium size room with 11' ceiling and about 15 x 20
Amd im really going for a balls to the wall rock thing
Old 02-21-2005
Son of Mixerman's Avatar
Son of Mixerman Son of Mixerman is offline
Mix Junior
Son of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond repute
What do you mean solid?
New heads?
Tighten the wires, tape the top little by little to shorten the decay sometimes I use silly putty along the edges on top. If the snare sounds go in the room and the mic isn't capturing it then the mic are in the wrong spot 99% of the time. IMO, get rid of the 58 on the hihat and let the 87's capture that since most hats close mic'd sound like doo doo to me.
SoMm
Old 02-21-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
What size snare are you using? How is it tuned?
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 02-22-2005
wimat wimat is offline
Junior Member
wimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond repute
Two words: Duct tape.
Old 02-22-2005
Raw-Tracks Raw-Tracks is offline
Force of Nature
Raw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond reputeRaw-Tracks has a reputation beyond repute
You really should try a different drum. You can mess with tuning and damping, but if it sounds like a "garbage can", and that is not the sound you want, you will probably have better luck with a new drum. Anything you do to treat the current drum may make it sound less like a garbage can, but it will still have that quality.
By "garbage can" snare sound, do you mean it sounds like the snares on Metallica's "St. Anger"? That's what comes to mind.
Eric
Practice Your Mixing Skills!
Mix Our Tracks in Your DAW!
www.Raw-Tracks.com
Online Mixing Forum
Old 02-28-2005
Supercreep's Avatar
Supercreep Supercreep is offline
Immortalizes Your Member
Supercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond repute
Lose the 58. Replace the heads and snares. Carefully inspect the bearing edges of the shell. If it's in good shape, tune it up correctly and then apply what dampening you need to achieve the sound you're looking for. For a heavier rock sound yo might want to tune the snare a little lower than you might expect. Dampening rings can be cut from old heads. Moongels are great. Use two and play with the spacing to really get some different tones out of the snare. Avoid duct tape if at all possible unless you like gummy heads. I reccomend using gaffer's tape if you must use tape at all.
Old 02-28-2005
BroKenSticKs's Avatar
BroKenSticKs BroKenSticKs is offline
Junior Member
BroKenSticKs has a spectacular aura aboutBroKenSticKs has a spectacular aura about
Sounds like the drum needs to be tuned. Get the drum sounding good in person then its just a case of capturing the sound to tape(may require tweaking)
Old 03-01-2005
fritzmusic fritzmusic is offline
Senior Member
fritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond repute
Just curious, is the snare sound trashy before you record at all in the room or does it sound trashy only after you've recorded? Your answer will tell you where to focus because if it sounds fine to your ears in the room, you're either not positioning your mics properly to capture the sound accurately or you're not using the right mics for the application or a combination of both.
Honestly, I've NEVER been able to easily achieve a great snare drum sound using SM57's and 58's (while not having the attention span/sanity long enough to scientifically play with every variable of proper mic placement in the room to get a basic "true" sound from the 57's/58s) until I purchased a Marshall MXL990 Large Diaphragm condensor mic and it picked up my snare just as my ears heard it in the room. The "recording curve" to a great sound is much less than than the 57's/58's and you'll see them as simple toys after playing with a more accurate LD mic. I haven't regretted that purchase one bit. Overall, the Marshall LD general purpose mics (not the overhead mics- e.g. 991s) or ANY L.D. condensor mic are absloutely a step-up and great for using on recording drums (especially when you apply light compression) and the Marshall's won't break the bank price-wise.
Old 03-01-2005
billmcdonald's Avatar
billmcdonald billmcdonald is offline
Senior Member
billmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond reputebillmcdonald has a reputation beyond repute
drum tuning bible
Old 03-02-2005
syrupcore syrupcore is offline
Newbie
syrupcore is on a distinguished road
awesome advice above. a quick check on your mic placement without having to move anything is: how does it sound in the overheads? if it sounds good there then you know it's the close mic/placement. it's proly your drum though.
goodies!
Old 03-02-2005
northsiderap's Avatar
northsiderap northsiderap is offline
Dedicated Member
northsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of light
Garbage Can
Hey, why try to make an apple sound like an orange?
If you want to record something that sounds like you hitting a garbage can, hit a garbage can.
Seriously.
I"ve played garbage cans before. It helps to suspend at least a little of it off of the floor so that the air/sound doesn't get trapped inside and it resonates to the outside room.
You can even tape snares into the garbage can. I've duct taped chunks of metal, etc in there.
Once someone stole my Ludwig snare back when I was super broke, so I used a weak old metal chair on my recordings for a while.
  #12
Old 03-02-2005
bleyrad's Avatar
bleyrad bleyrad is offline
Force of Nature
bleyrad will become famous soon enough
One time I put two Skill Saw blades on the garbage can lid and it sounded awesome.
I think though you might have missed the part where he implied he DOESN'T want it to sound like a garbage can.
  #13
Old 03-02-2005
Dedicated Member
Dang
Sorry, just woke up when I posted that.... A good snare is hard to find...
Trying to get the perfect snare sound... which snare should I buy??? pisces7378 Drums and Percussion 2 08-16-2004 06:02
Recording punchy snare ecktronic Recording Techniques 12 08-14-2004 21:13
Snare Tracking Recording Engineer Recording Techniques 27 01-22-2004 13:33
recording drums: snare nuisance rats Recording Techniques 20 04-03-2003 05:37
Neat snare recording trick... tubedude Drums and Percussion 8 01-18-2002 22:14
