Old 02-20-2005
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
does anyone mic the bottom
does anyone mic the bottom of the snare if so what mic should i use
Old 02-20-2005
Chibi Nappa Chibi Nappa is offline
Force of Nature
Chibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond repute
Sometimes... but I find micing the side of the snare to be much more useful. An SM57 should be fine. Put the mic near one of the small holes in the snare shell, but angle it enough so the air doesn't make the mic pop. I find this is a better sound than the underside of the snare.
Old 02-20-2005
SOUND
good idea
ill give it a shot ...thanks
Old 02-20-2005
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Thumbs up
Same same here.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 02-20-2005
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Sometimes I mic the bottom of the snare. My guidelines:
1.) Dynamic mic--usually a SM57, but I've put SM7's, MD421's and RE20's underneath.
2.) Put under mic out of phase.
3.) Gate the under mic snare during mixing.
Old 02-21-2005
Todzilla's Avatar
Todzilla Todzilla is offline
Force of Nature
Todzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond reputeTodzilla has a reputation beyond repute
I've had good success with a LDC - a Neumann U89, in particular.
Cloneboy's right about phase. Flip it opposite top mic, as the top head goes in, the bottom goes out.
Insect Massage Therapist
HUGE sound generation & capture facility
http://www.toddejones.com
Old 02-21-2005
xstatic xstatic is offline
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I usae a 414 usually on bottome snare. Often times you will need to check the phase on the bottom mic, but always check it. The way I like to position my bottom mic it often sounds better in phase.
Old 02-21-2005
LRosario's Avatar
LRosario LRosario is offline
Dedicated Member
LRosario is an unknown quantity at this point
SM57 on top
A good small diaphram condenser on the bottom (gets those highs really well).
And if you decide you don't want it, just cut it from your mix
Input from Orlando
Lee Rosario
Tracking and Mixing
(C) The Cubian Dreams project (Frankie's first engineering project! I'm proud of him!)
Old 02-21-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
I mic the bottom every time. I use a 57 (mostly) and have had good luck making sure the bottom mic is the same distance and angle as the top mic. Of course you have to hit the phase button.
I tend to gate the top mic during mixing and leave the bottom mic open.
I have also mic'd the side which can work great in certain situations. As you can tell, there is no absolute right way to do it, if it sounds good it is good.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 02-21-2005
Son of Mixerman's Avatar
Son of Mixerman Son of Mixerman is offline
Mix Junior
Son of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond repute
I never mic the bottom.
When was the last time someone stuck their head under snare?
It would take too long to explain it and I'd tick off somebody saying it so I'll let you suffer
SoMm
Old 02-21-2005
SoMm
A funny side. At a local two thousand-seat gig, when the name band came up, even as the mc did his intro I thought for sure, blown HF driver. The band played, more torn aluminum sound - a nice hot bottom snare mic.
  #12
Old 02-21-2005
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
[QUOTE=Son of Mixerman]I never mic the bottom.
When was the last time you stuck your ear an inch away from the top of a snare?
Never had much luck mic'ing the snare bottom myself, although the snare side thing I've yet to try out.
  #13
Old 02-22-2005
Mix Junior
Lot of times and actually I've had my head underneath too. Maybe thats why I don't do other things.
SoMm
  #14
Old 02-22-2005
franksquid franksquid is offline
Junior Member
franksquid is on a distinguished road
Using a 4 mic setup(XY overheads, snare, kick), I use a SM57 or M88 on the bottom with reverb. Sounds great to my ears. YMMV.
  #15
Old 02-22-2005
EleKtriKaz EleKtriKaz is offline
Home (w)Rec'r
EleKtriKaz will become famous soon enoughEleKtriKaz will become famous soon enough
You're only micing the bottom? If you're doing top and bottom that would be a 5 mic setup: x, y, kick, top, bottom.
In vino veritas.
  #16
Old 02-22-2005
enferno enferno is offline
Senior Member
enferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond reputeenferno has a reputation beyond repute
i usually mic both the top and the bottom. doing that you have to make sure that you flip the phase on the bottom mic 180. these 2 mics blended with the overheads gives a great snare sound.
  #17
Old 02-22-2005
Junior Member
On the current project I'm working on, the snare was very dry mic'd on top in the X/Y, kick, snare configuration. I placed the mic on the bottom of the snare about 3" away from the snare wires and added a little brite reverb. It worked like a charm in this case but I don't see myself doing that all the time!
  #18
Old 02-23-2005
Ronan's Avatar
Ronan Ronan is offline
Force of Nature
Ronan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond repute
Almost never.
Ronan Chris Murphy
Ronan's Recording Show My "TV Show" about recording.
Home Recording Bootcamp teaching other guys how to get in trouble
  #19
Old 02-23-2005
logan logan is offline
Junior Member
logan is on a distinguished road
botom allways
i allways mic the bottom. everyonce in awhile the side. i just find that the bottom mic gives me the sizzle that i want mix with the top mic. but sounds like crap if its outta phase . so i allways makes sure my bottom snare mic and my over heads are both in phase ..sounds better to my ears and i use 57's even a 58 sometimes for country.
sir... the mics not the problem......
  #20
Old 02-23-2005
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Everytime I do I'm sorry I did... I can never get those mics to sound worth a damn.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
  #21
Old 02-23-2005
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
it depends on the song and the sound i want. sometimes i do, most often i don't. like others, i tend to go for an LDC about 6in from the shell of the snare, aiming at the side. that's a nice woody crack there.
i've taken a shine to taping an MXL603 to one of my shure 545's (pre-sm57) and putting them both on top of the snare, side by side. that's a really neat sound too. lots of body and mids from the 545 and lots of whack and top end from the 603.
cheers,
wade
  #22
Old 02-23-2005
Jburn34's Avatar
Jburn34 Jburn34 is offline
Dedicated Member
Jburn34 is on a distinguished road
I mic the side a lot of times (try a SP C1) to get that nice rattle sound. I've had a lot better luck with the side than with the bottom. To be honest, though, I usually just use SoundReplacer now.
Jeremy
  #23
Old 02-23-2005
Thread Killer
< try a SP C1 >
i've used the SP B1 in that role to great success. in fact, that's one of my favorite uses for the B1.
cheers,
wade
  #24
Old 02-23-2005
uncle_j73 uncle_j73 is offline
Newbie
uncle_j73 is on a distinguished road
snare bottom
I got to use an Audio Technica AT835b condenser on the bottom of my Tama steel snare on a project a few months ago and it sounded awesome. I rarley hear such a good sounding bottom snare sound. Mixed it in with an SM58 on the top and wow.
  #25
Old 02-24-2005
johnsuitcase's Avatar
johnsuitcase johnsuitcase is offline
Senior Member
johnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond reputejohnsuitcase has a reputation beyond repute
I've tracked bottom mics a few times, never used it in a mix, though. I think if you are careful about top mic selection and placement, the drum is properly tuned, and you use compression correctly, you can get the best sound from the top head. The overheads should pick up a lot, as well, if they're properly placed.
My big problem with the bottom is that it seems (to me) to "fuzz up" fast rolls and ghost notes. The snare should have nice body, but that's more of a compression issue, in my experience (and also depends on how tight the snare heads are, and how the drummer hits it!). I try to be very careful to preserve the clarity of the attack first, then fill in behind it, if that makes sense...
Suitcase Recordings Location Recording in Phoenix, AZ
My Top Recording Tips:HomeRecordist
nanocomp better than art tube mic pre? trdn1 Other Equipment and Reviews 2 03-11-2006 12:22
FYI - Thinking of getting a Marshall mic - you need to read this! bvaleria Microphones 30 10-05-2005 08:16
Beginner's Mic Queries!!! Ma/T Microphones 4 07-28-2001 01:26
NT1 Rode ? Ears Microphones 24 06-27-2000 09:16
