Old 02-19-2005
doriangrey doriangrey is offline
Senior Member
doriangrey is on a distinguished road
Can you EQ the kick on a drum loop?
If you needed to isolate and EQ only the kick on a drum loop (s) to synch up with the bass, how would you go about it? Would you cut and paste just the kick portions of the loop on another track and eq that track? How would you align the kick drum to the proper timing placement?
I'm using Cakewalk GTP 3 which has some features like Sonar. Does someone have the answer to this? Thanks..
Derek
My DAW set up:
Mics: Royer 121, EV RE20, SM57
Mic Pre: Great River MP1NV ( sold )
Compressor: ART PRO VLA
Sound Card: EMU 1820m
Recording Software: Cakewalk Guitar Tracks Pro
Pentium III, 80 GB HD, 512 MB RAM, Windows XP
Old 02-20-2005
Bulls Hit Bulls Hit is offline
Been Here, Posted That
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
The way I'd do it is blow up the wave form & split the drum track right on the first kick. Position the split so you pick up all the kick transient, but no space before the kick. Now go to the same position in the next bar, or however long the loop is and split in front of that kick, in exactly the same place.
Put a volume envelope in the clip you've created to remove everything except the kick, and paste as many times as you like onto a new track. Make sure you paste the envelope while you do it.
Now you can eq the kick, but remember you still have the original kick on the first track. You may want to envelope that out of there as well
Old 02-20-2005
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
Multi-band EQ/compression?
Q.
<insert something witty here>
Old 02-20-2005
Senior Member
Q.
That would work too. But there is a certain amount of compression I need to use just for the kick to interlock with the bass track to get that thump. I don't want the compression to interfere with the snare, cymbals, ect.
My DAW set up:
Old 02-20-2005
Senior Member
That's good thinking. I will see if I can get that to work for me.
My DAW set up:
Kick Drum Mic and My Set Up zackformula Microphones 6 01-22-2005 22:28
kick drum head - holes & sound question teainthesahara Drums and Percussion 6 02-20-2004 07:56
Kick drum vs. Bass Guitar Round 1 Scottgman Mixing / Mastering 11 01-29-2004 04:50
Kick Drum Suggestions Douhgy Mixing / Mastering 1 01-14-2003 18:53
kick drum mic (sm58 no good?) wes480 Drums and Percussion 15 03-01-2002 18:43
