How to have inputs to mixer get recorded also
I want to be able to have anything plugged into a powered mixer to have it's own channel in a recorder. So what's the technique used? There aren't outputs for each channel on the mixer and I don't want to record the mix since I'll want to try and mix it later. The powered mixer will be used for the live sound. So do I need a direct box for each one of those? Can't just split the signal, right?
Does the mixer have channel inserts? You can use those as outputs.
Yes, there are inserts. I thought an insert was a stereo plug that sent and returned a signal. That doesn't sound like it would work right.
That's right. However the way inserts are typically wired, when you insert the cable halfway, the tip of the cable connects to the return. The return is internally wired to the send unless the cable is inserted all the way, so you effectively get a direct out without interrupting the internal signal path in the mixer.
If you're in an environment where halfway-inserted cables might get bumped, you can also wire a special cable that works when fully inserted (you wire the tip and ring to a single wire at the mixer end, and use a TS plug on the other). |
Ah, I see. I was just reading about that in the manual for one of the Mackie mixers. Thank a bunch, mshilarious.
One thing I noticed, there aren't as many inserts as channels. So what is the technique when you don't have an insert? |
Inserts are for things like outboard processors, so that's probably going to get you as far as a car with square wheels.
You'd need to check if your mixer has individual channel outputs. It may be something like a quarter inch jack or an XLR out. If it does, and assuming you have a multitrack with multiple input capability, then you can get individual tracks recorded.
Input from Orlando Lee Rosario Tracking and Mixing (C) The Cubian Dreams project (Frankie's first engineering project! I'm proud of him!) |
Which Mackie mixer do you have? Dave MorehouseLast edited by up-fiddler; 02-20-2005 at 11:37.. Reason: Wrong url |
hmmm, as others have mentioned in this thread, if you're in a bind you CAN use inserts as direct outs (and they're usually pre-fader/eq as well!) Just tap the send using the half-click method and you're set. I've done this with my Mackie 1202 into my Delta 44 with no problems. I guess I'm happy driving my square-wheeled car! -Evan "never went to school for recording but know that inserts can be used for direct outs if you don't have direct outs" Quote:
My drums |
Which Behringer Mixer is it?
#13
Thanks Evan, you make your point as elegantly as ever.
![]() And it's true, I don't want you guys to misunderstand me. I'm only saying that there are better ways to get a better recording, just trying to open yazoo up to other ideas. ![]()
| Mixer and using by PC | RRWagemakers | Digital Recording & Computers | 8 | 01-07-2005 08:50 |
| Options, or proper ways to connect 1/4TRS plugs into a mixer that only has rca inputs | Voxbeatz | The Rack | 9 | 02-01-2003 22:19 |
| Digital Mixer (Yamaha O2R) or a good analog mixer with a controller? | pisces7378 | Digital Recording & Computers | 6 | 10-31-2002 14:54 |
| Help!! using mixer with delta 10 10 | rastary | Recording Techniques | 9 | 06-28-2002 07:21 |
| How to record an audio track and what is the big advantage? | rdeboer | Cubase User Forum | 15 | 10-10-2000 21:08 |
