Old 02-19-2005
scottfisher scottfisher is offline
Senior Member
scottfisher is an unknown quantity at this point
Typical.
Typical n00b. I want an area to record some demos, just acoustic guitar, micing some amps, mostly vocals. Nothing special.
I have a (roughly) 8ft x 8ft area to have for recording. My computer/editing area is outside of that room, I'll just have the cables run to my mixer. The other room is about 12' away from that room. I can have the cables run along the floor or ceiling.
So the equipment/area is good for me, dont need windows, or a "control room". Im in the basement, and want to have that 8 ft x 8 ft room soundproofed for as little as I possibly can.
Here are three pictures of the room. Right now, there are no walls seperating it from another room beside it, and no door, but that is a given. It is also right near the furnace.
Picture One
Picture Two
Picture Three
Old 02-19-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Are you trying to keep sound in or out? Are those stairs running over the room?
Old 02-19-2005
Senior Member
No, the stairs are a bit further away.
Want a good area for the vocals and acoustic guitar to record. So yeah, keeping sound out. An ideal area for the best sound, at the lowest possible price.
Old 02-19-2005
Rod Gervais Rod Gervais is offline
Force of Nature
Rod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond reputeRod Gervais has a reputation beyond repute
Ms,
Just a thought - for what it's worth - there is no difference....... any assembly works exactly the same in both directions.......... so the only question with isolation becomes that of what the required assembly rating is........ not where the source is.
Rod
Old 02-19-2005
Senior Member
I re measured the room. It's acctually 8.5 x 11.
Old 02-20-2005
Faithful Departed
Originally Posted by Rod Gervais
Ms,
Rod
That's the point--the required assembly rating. Drums are a lot louder than the TV in the next room
Old 02-20-2005
Senior Member
Bump.
(For the ten characters...)
Old 02-20-2005
Faithful Departed
Well, isolation requires construction, which doesn't have to be expensive, but it could be involved.
How willing are you to tear off the drywall? What's your budget?
Old 02-20-2005
Senior Member
Very willing to tear drywall. Its my house.
Well, I want to spend as little money as I can. How much are we looking at?
Old 02-20-2005
Faithful Departed
One approach would be an exterior door with weatherstripping, insulate inside the walls, and hang two layers of drywall on resilient channel. Redo the existing vent with a long length of flexible duct to a larger vent. Hang a few sheets of rigid fiberglass insulation on the walls, and maybe one from the ceiling.
For a 8'x8' room, that would be somewhere between $500 and $1,000 in materials.
How about a floorplan? Can you post that, showing adjacent rooms too?
Old 02-20-2005
Senior Member
Ill work on making one. I have the floorplan of my house, but no scanner. I'll work on one. Any good programs for that?
Its beside a laundry room with a furnace, a bedroom, the stairs, and a living room. Not many people down here, but some people walking around up stairs.
Typical Rack Sizes? and how to build rack space into a desk. Mongoo The Rack 15 12-05-2004 10:14
what is typicaL lifespan of cd burner? fenix Digital Recording & Computers 7 10-25-2004 09:42
the typical LP sound rataplan Keyboards and Sound Modules 4 07-05-2004 15:23
Sonar Audio->Options->latency, typical settings? ryan_temp Cakewalk / Sonar Forum 1 01-29-2002 17:25
