Thread Tools | Display Modes |
Foxtex VM200: control Sonar via the Universal Control Surface Plug-in & macro player
02.17.05 VM200 How to
I am using the Universal Control Surface (UCS) plug-in to control Sonar with a Fostex VM200. The VM200_UCS.zip file and other UCS docs can be obtained at http://groups.yahoo.com/group/universalcontrolsurface (((This group discusses the development of the "UCS", a universal control surface being developed by Marc(mbncp). The UCS is an advanced full duplex control surface for use with Cakewalk Sonar. UCS is in the early stages, a beta test version is expected soon. ))) ================================== NOTE: Only ONE preset is available. This is the UCS_beta3.ini file. Backup this file before changing. FOR MACRO'S ONLY: rename the UCS_beta3.ini file Rename the macros only UCS_beta3.ini file to UCS_beta3.ini ================================== The UCS is also a MACRO editor / player: NOT a recorder. However, lottsa stuff can be controlled by hot-keys, and by assigning a MIDI controller to a Macro. See: UCS Help 1003d WordPad format.doc for Sonar parameters: TransportTime, TransportState,... Command Actions for Sonar 3 PE.txt, Command Actions for Sonar 4 PE.txt for menu items,... And: review the INI and other docs for examples. ================================== The included example Sonar project file has 32 audio tracks and 16 busses. More of each can be added. Including Midi tracks. Note::: This setup works with existing projects. 32 tracks, 16 buses are NOT required to use the included vm200 INI configuration. A macro can be added in the ini to switch Bus Banks if more that 16 buses. And the UCS dialog can be used to switch banks. Note: if there are not a matching number of tracks/buses, switching banks will result in the VM200's fader 16 controlling the last track/bus. Sometimes Bus16 does not respond. This is intermittent. During testing (changing stuff a lot) Sonar sometimes lost the midi in port. Do not know why. If this happens, enable the midi port connected to the VM200. Then Click Options | Control Surfaces, double click UCS and select the proper MIDI port. ====================================================== The included INI file is configured to control: Sonar Tracks: (in VM200 channel mode) Fader Pan Solo Send 1 volume (in VM200 effect 1 mode) Send 2 volume (in VM200 effect 2 mode) Sonar Buses: (in VM200 channel mode) Fader Pan Solo Send 1 volume (in VM200 effect 1 mode) Send 2 volume (in VM200 effect 2 mode) Fostex Master (red) Fader in channel mode Sonar Master Volume Fostex Master (red) fader when in various modes (not enabled/assigned in current INI file) Aux1 Master Volume Aux2 Master Volume Aux3 Master Volume Aux4 Master Volume Effect1 Master Volume Effect2 Master Volume Fostex Master Channel ON button switches between the track and bus panes. ==================================================== NOT enabled in this ini: Channels 17- 20 do work. But the effects sends are confusing: Channels 17-18 Effect1 send does not work Channels 19-20 Effect2 send does not work The faders/pan controls/Chan On/Off could be configured to do other stuff: EQ maybe. I have not attempted this. ==================================================== ============================================= MACROS: current macros in INI file Shift + Windows + U Open the UCS dialog, load default ini file Shift + Windows + i load default ini file Shift + Windows + Left Arrow Move Track Bank left Shift + Windows + Right Arrow Move Track Bank right Shift + Windows + Up Arrow Control Tracks Shift + Windows + Down Arrow Control Buses Shift + Windows + i Insert new audio track Then: Display Name, Inputs, and Outputs dialogs Set input monitoring on Arm for recording Shift + Windows + d insert new MIDI track Then: Display Name, Channel, Outputs, Bank, and Patch dialogs Arm for recording ============================================= TO INSTALL Expand the VM200.zip file to the c:\ root folder. This will create these folders: C:\AudioCommon\UCS\ucs_stuff And copy all the files to these folders ================================================= VM200 setup: MIDI: Set Transmit and Receive to Channel 16 Set Control change RX and TX to ON Set System EX RX and TX to ON Set Program Change to Table 02 Current Scene Status Set Add Aux to ON Set smoothing to level 1 Set AUX PAIR to OFF Set all Channel On/Off buttons to OFF Save this Scene. (If ya want, do a bulk dump to a MIDI library program for quick reset.) ================================================= UCS setup: Double click the "Register.bat" file in the c:\AudioCommon\UCS folder. (Do this only once.) (( Note: The C:\AudioCommon folder is where I install programs and shared content I want quick access to without having to explore to an annoyingly buried folder. E.G., C:\Program Files\Cakewalk\Sonar4\shared content\templates\,.... Also: I have installed programs such as Sonar1,2,3,4 to folders in the C: folder: i.e., C:\Sonar1, C:\Sonar2, etc.,... )) Open Sonar Load the "32 channels 16 buses.cwp" file in the c:\AudioCommon\UCS folder. Click: Options | Control Surfaces Add the UCS choose MIDI In / Out ports connected to the VM200 click OK to exit dialogs Press Shift + Windows + U To open the UCS dialog, and load default ini file. (Only 1 preset at this time.) (If this does not work: Click Tools | UCS Click Edit Click File | Save and Update Click X to close editor.) Test controls. SaveAs to use with new project. ============================================== This setup works with existing projects. But, you may have to Press Shift + Windows + U To open the UCS dialog, and load default ini file. ============================================= Reference: VM200's manual, page 212, for Midi messages sent by the VM200. Note: message 32 not used messages 9 - 104 not used The VM200 does NOT send Fostex System Exclusive messages as stated on page 217. ============================================= 02.17.05 Jesse Jesse3@Lansing.com |
| Check out this new board/controller from TASCAM | SPINSTERWUN | TASCAM User Forum | 31 | 02-08-2004 06:43 |
| Upgrade path opinions... | mikedaul | Digital Recording & Computers | 8 | 12-10-2003 09:57 |
| Anyone use Tascam DM24 with sonar 2.2? As a Control Surface? | rcktdg | Cakewalk / Sonar Forum | 5 | 12-09-2003 10:48 |
| Control Surface support for Sonar...Is the Tascam US-428 the best value? | tcdave | Cakewalk / Sonar Forum | 21 | 08-18-2003 21:34 |
| sonar control surface issue | ravyr | Cakewalk / Sonar Forum | 6 | 05-22-2003 02:12 |
