Old 02-16-2005
jerzeysk8board's Avatar
jerzeysk8board jerzeysk8board is offline
Senior Member
jerzeysk8board is an unknown quantity at this point
cakewalk sonar 4
I hear fast tapping when i play back my recording on sonar 4. Also hear kind of an echo some times. What should i do to stop it? What icon or where do i go? Please Help
Old 02-16-2005
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Work with us here, sk8. We need a little more to go on.
The fast tapping could be a metronome. Is it in time to the music?
The echo could be Input Monitoring. Does it happen while you are recording only?
Please provide as much info as you can. How many tracks in the project? Midi and Audio? How is the midi being played, soft synths? What is your sound card. Etc.
Old 02-16-2005
Senior Member
I am using a m-audio mobilePre. I am not using the metronome. When im recording and monitoring it it sounds fine. When i play back it i hear tapping and sounds sort of distorted. The sound isn't clear.
Old 02-16-2005
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Does it sound more like choppy audio rather than a tapping soune mixed in?
She's not the boss of me
Old 02-16-2005
Senior Member
yeah kinda of
Old 02-16-2005
Senior Member
Is the computer audio suppose to be coming out of my headphones. How do i turn them off, maybe thats the problem. But then how can i playback my recorded track.
Old 02-17-2005
punkin's Avatar
I'd start by deleting the aud.ini file then let the application "re-evaluate" the audio card. I've had that sort of thing when the "Playback Timing Master", "Record Timing Master" don't match for the actual device(s) you're trying to use (see the "Options -> Audio" tab). Also make sure that all your tracks are set up to record and play back. I usually have the track inputs match the recording audio interface (duh) and the out put for each of the tracks going to busses then the busses going to the Master...the master output needs to be the same as the "Playback Timing Master".
The point I'm trying to make is be sure that your not trying to mix functions or features between two different audio cards.
Old 02-18-2005
Porter's Avatar
Porter Porter is offline
aka WookieMan
Porter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud of
Are you recording through one card and playing back through another card?
As Sonar doesn't like it too much
Just a thought..
Daniel
Cakewalk gone Wild!! Sonar Help Needed!!!!!! MercyfullMusic Cakewalk / Sonar Forum 1 01-15-2004 18:29
Protools Vs. Cakewalk Sonar 2.2 XL bluesignal Newbies 21 09-29-2003 05:17
So what are the advantages of SONAR over Cakewalk 9? tsphillips Cakewalk / Sonar Forum 3 06-14-2002 08:51
New Cakewalk Sonar email discussion list Synth2k Cakewalk / Sonar Forum 0 03-08-2001 17:35
Cakewalk 9 and Sonar prices DavidK Cakewalk / Sonar Forum 6 02-06-2001 09:59
