Can anyone explain the main use for a direct in box ? Should I be using one for my SM57 into a Tascam 244 recorder ? Should I be using one for my electric guitar directly into my recorder?
Thanks |
A DI will match a high impedance output to a low impedance input or vice versa.
It also can do the folowing * Reduce Hum, Buzz, electrostatic interference * Helps output a stronger signal ( if your instrument wont put out enoungh, you can Di to the mic preamps on your mixer * An active DI can give you a cleaner low end and clearer highs * combine a direct signal through the DI to mixer and a miked signal from the same di to miked amp to mixer. You don't HAVE to use a DI but there are benefits. [This message has been edited by Shailat (edited 02-02-2000).] |
I mainly use a DI box in live situations. The Guitar goes into the DI and out to an XLR connector to the Snake and mixer... also I have another guitar cord coming out of the DI box to my amp, so I can hear myself as I play. The main house speakers carry the signal that The audience hears.
Dom Franco |
I only use DI's for a raw (non amped) Guitar/bass and for converting jack to XLR.
I run sound for a local band... and instead of putting a mike on the bass amp I run from the bass preamp out into the di and then into the mixer. That's my use... dunno if it's correct but nothings burned yet.
