Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-14-2005
Cuzme's Avatar
Cuzme Cuzme is offline
Tonal Evangelist
Cuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond reputeCuzme has a reputation beyond repute
There's a radio inside my NTK!!
How can I get it out? Can I at least change the channel?
My NTK sounds great on what it's recording but picks up a strong radio signal at my new abode. Can I fix this somehow or does it mean that I just can't use the NTK at my new crib? I won't be able to check it again until Wednesday but I'd appreciate any advice that is out there. Thanks,
Chris
A one that is not cold is hardly a one at all.
Cuzme (Cooz-me) n. 1. A tireless creative force of energy 2. A class act 3. Lover, not a fighter
www.cuzme.com
www.myspace.com/cuzme
Old 02-14-2005
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
1. Is this a commercial station. They may be exceeding their licensed signal strength.
2. Are you sure it is the microphone? It might be just as likely, if not more so, that the signal is being picked up by, for example, your cables. Run some tests.
Old 02-14-2005
Cuzme's Avatar
Tonal Evangelist
I've tried different mics with the same cables and did not have the same problems...
My suspicion is that it is in the power supply or the loong 7pin cable that connects the mic to the power supply. I don't need one that long and a shorter cable would probably do the trick? But are those 7 pin cables readily available? I may have to order a new one from NTK.
I realize there's not really a radio in the mic, it sure sounds like there might as well be though.
Do different cables pick up different signals? I have also moved the mic and the cables all around my apt attempting to ditch the radio sig. Very frustrating,
Cuzme
Thanks Innovations, much love.
www.cuzme.com
Old 02-14-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Somebody posted this link last week, good stuff:
http://www.audiosystemsgroup.com/publish.htm
Scroll down to the "Pin 1 Revisited" papers.
Old 02-14-2005
Cuzme's Avatar
Tonal Evangelist
Wow. good stuff...all of it. Thanks,
Cuzme
www.cuzme.com
Old 02-14-2005
paddyponchero's Avatar
paddyponchero paddyponchero is offline
Force of Nature
paddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to all
Chris
Try solder a couple of capacitors 100pf-1nF between pins 2 and 3 and ground. You can do this in the mic for a permanent fix or in the cable at the mic end. Ideally add a ferrite bead on the wires to pin 2 and 3 also.
DOH! sorry just realised it was an ntk - try the capacitors in the xlr at the power supply end.
You could cut down the cable but it might not eliminate the problem completely.
Old 02-15-2005
Bob's Mods's Avatar
Bob's Mods Bob's Mods is offline
Force of Nature
Bob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond repute
I was having this same problem with my M9. I live near a commercial radio tower and sometimes the powerful signal can get into my mic. In my case, I found the connector shell that mates to the M9 had paint on the inside. This caused the mic body not to make solid contact with the cable shield. Using a dremel tool I removed the paint to expose the metal. Once the mic body made solid contact with the cable, the problem went away.
If you live near a radio tower, you find this problem in other gear you own. I've had to fix this problem on a case by case basis. Sometimes it's trial and error.
Bob
May You Live All The Days Of Your Life
Old 02-17-2005
crazydoc's Avatar
crazydoc crazydoc is offline
Master Baiter
Location: Please forgive me. I don't mean to be a prick, but I guess I am.
crazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond repute
I tried to post this link the other night, but things were all screwed up at psw - back to normal now. Anyway, there's some good info in this thread.
http://recforums.prosoundweb.com/index.php/t/1894/0
I'm going through a difficult period - it's called life
Unhappy with my NTK... frist44 Microphones 32 08-16-2002 17:35
NTK... Mini Review Buck62 Microphones 6 06-02-2001 00:38
