Old 02-13-2005
jukeboxbreakdow jukeboxbreakdow is offline
Newbie
jukeboxbreakdow is on a distinguished road
Red face phantom power and rack units
hello !
I have a rode nt1, im about to record some vocals and wanted to go via my behringer composer pro then into my soundcard.
the nt1 requires phantom power, my soundcard (tascam us122) can provide phantom power.
so is it as simple as chucking the composer into the link and switchin on phantom ????
Im anxious about doing this incase i blow my composer
any ideas ?
Old 02-13-2005
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
It won't hurt your composer, but the unit won't pass phantom power. The mic won't work plugged into your composer. It needs to be powered first. Run the composer on the insert on your tascam. This is like an effects loop on a guitar amp. You need an insert cable. The signal goes out, through the composer, and back into your tascam.
Old 02-13-2005
Newbie
nice one
thanks man
Old 02-14-2005
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Are you sure? I would think the composer would have a differential output instead of a transformer balanced output which would mean that Behringer either put blocking capacitors in the signal path [which would fuck with the sound of the unit] or you will be able to pop the chip that drives the output [like the TL Audio crap] if you hit the backend with phantom power.
Other than that... no, you can't use the phantom from your soundcard to drive a mic through another unit.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 02-14-2005
moldin' oldie
True enough. The composer has servo-balanced outputs, but I did make the assumption that the caps on the output would be of sufficient voltage to handle phantom power.
Old 02-14-2005
Newbie
way over my head !
so is it going to cause a small explosion doing it that way or not ???????
Old 02-14-2005
moldin' oldie
Originally Posted by jukeboxbreakdow
way over my head !
It doesn't matter. It won't work anyway. Just hook it up with an insert cable, and you are good to go.
Old 02-19-2005
Newbie
hey, setting up to get the vocals done today and having a few problems
setting it up the way i was advised, i can now see that my compressor is getting a signal
however, im not getting anything back from it
any ideas ???
Old 02-19-2005
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
Are you using an insert cable or just a standard Y-cable? An insert cable would have the TRS plugs on one end, and two TS plugs on the other. A standard Y-cable would probably have TS plugs all around, and would send signal to the compressor but wouldn't return anything back.
Wiring up Neutrik combos with Phantom power pete_d The Rack 4 02-09-2004 08:13
Rack Power Chip Hitchens The Rack 5 10-11-2003 12:10
Newbie question:What is a preamp? to_see_me Newbies 4 01-15-2003 03:01
Rolls RPB623 Phantom Power Supply ianda The Rack 2 06-10-2002 20:31
Short power cords for use in rack. jw1 The Rack 3 02-09-2002 11:53
