Old 02-13-2005
Idgeit's Avatar
Idgeit Idgeit is offline
Dedicated Member
Idgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to behold
Patch Bay Noise
Hey all,
I've been told, if i get a patch bay, it'll add some noise to the recording. Is their anyway to avoid this?. In my studio, the amps and kit, are in another room, around 30ft away from the DAW. And i really need some patchbays for the long amounts of cable.
Thanks
- Idgeit
"Lets go with the milk....", "Lets go with the milk?", "Im sorry, could you bless me with some of your precious milk?" - Ricky, Trailer park Boys
Old 02-13-2005
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
Balanced cables or shorter runs. You really won't know how much noise is added if any until you hook one up to your system.
Old 02-20-2005
Wire Wire is offline
Junior Member
Wire is on a distinguished road
That is TOTALLY unture, who ever told you that was using a patchbay that was wired wrong or they were doing something worng. Every single Pro Sudio in the world uses patch bays and there is no extra noise, or humm or buzz if they are built correctly.
Adding a patchbay add about 3" of extra "material" to your wire. You will have no problem with a bay if it's done right. I am building bays every week and I have NEVER had a problem. There are the occasional pieces of gear that buzz, that end up needing a audio ground dropped or something, but you won't notice any change.
Please feel free to contact me if you need help with building your bays or need any parts to build them from.
Thanks
Old 02-21-2005
Idgeit's Avatar
Dedicated Member
ohh thanks ,
Can patchbays be used as connectors, say i got 5ft leads, and need to add on another 30ft, could i do the following
5ft lead --> Patch Bay ---> 30ft Lead
And use it as an extender?
- Idgeit
Old 02-21-2005
Junior Member
It can be used for anything invloving passing signal. I would get a 35' cable instead!
You are going to be spending alot of $$ to use it as a extender. A TT bay wired is going to start at more than $1000
What are you trying to do let me know, maybe there is a better way to do it!
Old 02-21-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
ok, so a thousand dollar patch bay won't add any noise. great. how bout a $90 one off of ebay?
Old 02-21-2005
Junior Member
"ok, so a thousand dollar patch bay won't add any noise. great. how bout a $90 one off of ebay?"
FYI...The $1000+ bay isn't just for the bay, that would a full wired 96 point TT bay, with a average length of wire coming off of it. The bay's run about $280 or soemthing like that.
But a $90 bay off of Ebay should be fine.
Two things I would stay away from are...
Very old bays, it doesn't matter if it cost's 10 bucks or $2000 because the metal over a long period of time builds up corrosion, which will lead to intermitant connections.
Another thing I would stay away from buying used is a 1/4" feed through bay. 1/4" bays serve there purpose but the feedthrough bays have a much shorter life span. A 1/4" solder bay wouldn't be a problem.
I sell 48 pt Neutrik feedthrough bays new for $75 so, don't buy one for $90 if that was what you are looking @
If you have any other questions or need bays shoot me a PM
Old 02-21-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
1/4" patchbays are cheap enough that you should just get a new one. The 1/4" bays don't last all that long, and you could very well end up buying someone else's problems. Better to start with one that is fresh.
Patch Bay strategies Middleman The Rack 14 04-17-2003 13:18
what is a good patch bay for $100-150? maskedman72 The Rack 17 02-28-2003 21:52
Patch Bay Hookup? Helpful Link CMiller The Rack 10 10-01-2002 04:40
Banyam patch bay DIY nyjoei Digital Recording & Computers 0 04-12-2002 10:04
Fostex 3010 Patch Bay chazba Free Ads for Music / Recording Equipment 0 12-22-2001 08:34
