Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-12-2005
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
Beyer M201 On Finger Picked Acoustic
Is it very wrong of me to feed the line in of Channel 2 of my Audio Buddy from Channel 1 to get a decent level without having to turn Channel 1 all the way up or have the mic so close it's practically touching the strings?
I can't afford a new pre amp
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 02-12-2005
asulger asulger is offline
Junior Member
asulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond reputeasulger has a reputation beyond repute
won't work - lots of distortion. The audio buddy (like most pres) has hi-impedance outputs. The inputs are lower impedance.
The low distortion rule is that whatever you plug into has to be the same or higher impedance.
You could solder a 1 megohm resistor in line with the center connection. That might work.
12-string tunes: CDBaby, iTunes, Rhapsody
Blog: 12-string Musings
Old 02-12-2005
OneRoomStudios's Avatar
OneRoomStudios OneRoomStudios is offline
Dedicated Member
OneRoomStudios is on a distinguished road
What's wrong with just turning channel 1 all the way up? Seems like that would be a lot better than pre-amping it twice (just asking for distortion). Just MHO.
-Peter
Old 02-12-2005
crazydoc's Avatar
crazydoc crazydoc is offline
Master Baiter
Location: Please forgive me. I don't mean to be a prick, but I guess I am.
crazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond repute
Should be no problem impedance and distortion-wise. Just take the output of one channel into the 1/4" (Hi-Z) input of the other. You'll have to fiddle with the gain of each stage to make sure your not overdriving the second channel into distortion or clipping.
The problem is going to be with noise, as you're also amplifying the noise of the first channel and adding it to any noise of the second. Again, by fiddling with the gain of each channel you can get this as low as possible, and hopefully will be less than by using a single channel and cranking it all the way up.
Let us know the outcome (as I'm too lazy to try it myself.)
I'm going through a difficult period - it's called life
Old 02-12-2005
Mark7's Avatar
Human 2.0
Actually I tried it and it worked surprisingly well. The Audio Buddy doesn't have a lot of headroom and gets pretty noisy above 4 O'Clock. The Beyer M201 doesn't have a great deal of output, and requires a lot of gain for this type of application. Put the two together and you get way too much noise. By sending a signal from Channel 1 into the 1/4" Line Input of Channel 2 I was able to get a reasonably quiet recording; without having to stick the mic right up against the strings or turn the gain up on either channel above 1 O'Clock (I used a setting of 1 O'Clock on Channel 1 and 10 O'Clock on 2).
If I had the means I'd post a sample.
BTW: No distortion
fantastic cheap ass acoustic jimistone Guitars and Basses 5 09-08-2003 19:16
Acoustic recording tips sprocket87 Recording Techniques 16 09-03-2003 08:46
Had a few beers and picked up the acoustic SLuiCe MP3 Mixing Clinic 51 08-13-2003 08:42
The best way to make an acoustic guitar heard live... microphone, pickup, or what? pisces7378 Guitars and Basses 9 03-19-2003 20:07
finger noise on acoustic guitar eddie27 Newbies 9 02-21-2002 12:13
