Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 02-12-2005
wildflower soul wildflower soul is offline
Senior Member
wildflower soul is on a distinguished road
telephone microphone
is there an easy way to convert a telephone into a microphone, or a microphone that sorta sounds like one?
Old 02-12-2005
vangore vangore is offline
Senior Member
vangore is on a distinguished road
you can get a telephone sound with eq quite easily bud
amd 64 3700
Digi 002
pro tools LE
Yamaha o3d
Korg ms2000
akg c414
Im in insider trading, ha just kidding.
Old 02-12-2005
Senior Member
but its not the same
Old 02-12-2005
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
Try singing or talking into something like a Hohnner Blues Blaster 1490 (Harmonica mic). It is a Hi-Z mic you will need a XLR to 1/4 cable.
Go into a guitar amp then mic the amp.
I also made a mic from a old phone handset. I used the speake part not the mic part and put a XLR cable on it I also tried it with a 1/4 guitar cable on it.
I picked up my Blues blaster for $30.00 used
Old 02-12-2005
OneRoomStudios's Avatar
OneRoomStudios OneRoomStudios is offline
Dedicated Member
OneRoomStudios is on a distinguished road
I just made a mic using the speaker out of a cheap set of headphones, talk about low fi! The only problem is that the out put is really low - have to crank my pre to get anything usable. Still fun to play around with though.
Old 02-12-2005
Adam P Adam P is online now
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
Try wiring the terminals of the telephone's microphone to a 1/4" TS jack and plug it into a passive DI, and then into your preamp.
Or just do it with EQ...
Old 02-12-2005
rdozz rdozz is offline
Senior Member
rdozz is on a distinguished road
With-in reason I can supply telephones to anyone on this board that needs one. I am a test engineer and I get a lot of proto-types to test acoustically. I fill up a large garbage can about every 2 weeks with cordless and corded telephones that work just fine. The company I work for is Clarity a division of Plantronics. We build amplified telephones for people with hearing impairments check out our web site.....If you need a phone all you need to do is pay shipping, I will be glad to dig the phone out of the garbage.
BTW. This is not a general-waste only phones and such.....
sorry US only shipping
Rob
Old 02-12-2005
applejax applejax is offline
Dedicated Member
applejax will become famous soon enough
I have a thing that i bought at Radio Shack a while back and it has a suction-cup on it and you put it on the back of the telephone where the ear piece is and it has an 1/8th in jack connector so i have to use a 1/8" to 1/4" adapter then run it into my VS2480 and record phone calls MU HA AHHAHAHA...just joking i only record certain telephone parts for some songs with it...but i have IN THE PAST recorded actual calls...
but Vangore is right...every1 usually uses the telephone EQ effect...if your using a DAW there is usually preset eq's that u can swap onto the input!
Old 02-12-2005
Senior Member
ya if you have a channel strip plug-in there should be a preset for telephone efect and it sounds very convincing
amd 64 3700
Digi 002
pro tools LE
Yamaha o3d
Korg ms2000
akg c414
Old 02-12-2005
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
if you have an old-style handset you can screw off the mouthpiece cover and clip onto the wires. If you have a phone with a separate handset there is a cheap adapter you can plug the handset into.
Old 02-14-2005
tallman tallman is offline
Senior Member
tallman is on a distinguished road
I am a true believer that the best way to get any effect is to really do whatever it is you are trying to do. If you want a vocal to sound like a phone call, then get on the phone, and have a microphone answer the call at the other end.
The microhphone in your telephone isn't solely responsible for the quality of the call. Your call gets seriously downsampled before being pumped into the reciever at the other end, and the earpiece also plays a big role. So do the amps in the telephones.
  #12
Old 02-14-2005
Senior Member
ya tallman has a very good point its primarily the downsampling that take of the bottom and the top and makes it sound the way it does
amd 64 3700
Digi 002
pro tools LE
Yamaha o3d
Korg ms2000
akg c414
  #13
Old 02-14-2005
Senior Member
Thanks vangore. Last time I had to use this trick, we were stuck with only one phone line, but my guitarist had a cellphone with a speakerphone in it. Because there is so much lag in the cell-network, we had to shift the track to make it synchronize properly later, but with a little eq'ing (just enough to give it a pocket in the mix) it sounded great. If you use all your EQ's on making something sound like a phone call, you might have none left to make it sit in the mix.
  #14
Old 02-14-2005
DJL DJL is offline
Banned
DJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to all
Checkout the telephone patch setting in the Boss VF-1.
  #15
Old 02-14-2005
Warhead's Avatar
Warhead Warhead is offline
Jai guru deva om
Warhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond reputeWarhead has a reputation beyond repute
It's been a while since I recorded a telephone part for real...but last time I did we took the phone off the hook until the annoying "brrp brrp brrp" stopped then just talked / sang through it with a mic on the receiver on another phone in the place.
War
Warren Dent
www.ZenProAudio.com
That's right....a new location for me!
  #16
Old 02-14-2005
Senior Member
War
Good tip.. at least that way it goes through most of the phone circuitry before hitting the other end.
  #17
Old 02-14-2005
noodles2k5 noodles2k5 is offline
Senior Member
noodles2k5 is infamous around these partsnoodles2k5 is infamous around these parts
It was more fun to make than it was to use.
Yeah, it's got XLR.
  #18
Old 02-14-2005
sleego sleego is offline
Newbie
sleego is on a distinguished road
You can obtain 99% of the effect w/lots more headroom w/an EQ and a virtual amp like AmpFarm or Amplitube. No wiring necessary!
Attention Newbies: Copy and Save This For Reference!!! (Pt 1) Buck62 Newbies 11 03-27-2009 15:57
All the World's Tube Microphones PART TWO Bambi Busboom Microphones 5 09-06-2006 13:16
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
Type of microphone for vocal Jack Real Recording Techniques 9 05-07-2003 11:25
First Microphone: SM57 or SM58? HomeRec Microphones 16 10-15-2001 10:52
