Old 02-01-2000
jimmyjames9 jimmyjames9 is offline
Senior Member
jimmyjames9 is on a distinguished road
Wink
man, i have a new found respect for all you home recorders out there. this is some tough shit. you run into one problem you solve it, boom, there's another. anyway, i keep getting a lot of popping when i sing. is it better to sing loud or soft, close or far, crank the pre or turn it down? shit, i'm lost i'd would appreciate any help. thanks.
Old 02-01-2000
BigKahuna BigKahuna is offline
Force of Nature
BigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond reputeBigKahuna has a reputation beyond repute
Wink
No problem.
You can buy a pop filter kit from a place like musiciansfriend.com to solve the popping problem. Basically, it's a nylon screen that is placed between your mouth and the mic and is softens the consenants that you use. I think these kits are around $30.
A home-remedy for this is a normal coat hanger bent into a circle with a nylon pantyhose (preferably clean) pulled over it. Tape it to the mic stand and bend the hanger so the nylon is between you and the mic.
Old 02-01-2000
gk-one gk-one is offline
Junior Member
gk-one is on a distinguished road
Wink
hi there
i definately agree that the pop filter is the way to go if you dont have one. they serve their purpose well. also mic technique can come in handy here. for a quick fix try singing into the mic at a bit of a side angle. the diaphram of the mic will not be quite as directly exposed to the power of your voice. just remember to adjust levels accordingly. good luck.
garrett
Old 02-02-2000
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
Unhappy
In addition to the pop filter, you might try placing the mic a bit higher and tipping the mic down about 15 to 30 degrees.
Old 02-02-2000
Senior Member
Wink
i'm using an sm-57 with some little foam thing that is supposed to help with popping (it doesn't seem to work). thanks for the help, i appreciate it! i think i'll try the pop filter kit.
Old 02-02-2000
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
Wink
There is a usefull technique that I heard from a enginer
that worked for me in a problematic word or 2.
Very fast turn down the lows below 100Hz at the word ( or part of the word.
Go with the pop filter- it is a very commen way to work
