Old 02-11-2005
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
Aux Effect?
is reverb a Aux effect or is it a insert or both
Old 02-11-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
The answer is both. The mix settings are different depending on how you use it though. When used as an insert the mix setting of the reverb box is 100%, as the mix is handled by the board. When using it as an inline effect the mix setting will typically be much lower, as the reverb box itself has to control how much effect to mix with the dry signal.
There are books on all this kind of stuff, you need to do some reading.
One really good book on mixing is called "The Mixing Engineer's Handbook" and is by Bobby Owsinski. I'd highly suggest you purchase it and use it as a reference. I keep it around for that reason, and have read it over and over.
An excellent book about fx is called the "Wizoo Guide FX", and is by Thomas Adam. It will answer the question you posed here, and many more, and is written in a very clear and understandable style. Highly recommended.
Old 02-16-2005
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
SonicAlbert's absolutely right, but as a generalized answer to your 'generalized' question: reverb is typically an Aux-connected processor as it's often applied to multiple tracks; Insert-connected processors would include compressors and gates.
Old 02-16-2005
SOUND
thank you for the direct answer
Setting up aux sends for hardware acidrock Cakewalk / Sonar Forum 6 05-19-2003 14:01
Use Of 2nd Aux jazzbass12 Cakewalk / Sonar Forum 15 04-29-2003 11:37
Aux Bus Problem Rick Clare Cakewalk / Sonar Forum 7 04-06-2003 16:39
Any ideas on good and cheap Effect processor? Sam420 Mixing / Mastering 3 06-03-2002 15:45
