Tube tape echo
can any one tell me if when using a tube tape echo box , it is supposed to add some distortion to the signal or should it be pretty clean when the tape echo is engaged
I would imagine that the effect has a "volume" knob ... so you should be able to dial in the distortion. if not you should be able to get a "cleaner" tube e.g. by using a 12au7 (gain factor ~70) instead of a 12ax7 (gain factor ~100) bye! alfred |
The reason anyone would mess with these things anymore is because of how it degrades the signal.
A well worn piece of tape, a thirty year old tube, and worn & dirty heads, distortion is inevitable.
i hear ya but it didnt sound like John Lennon had distortion on his vocal when he used the tape delay effect
That was probably a well maintained and new(ish) unit. These things could sound clean under the right conditions but, even then, the second or third repeat would be noticably darker and fuzzier.
| Attention Newbies: Copy and Save This For Reference!!! (Pt 2) | Buck62 | Newbies | 12 | 04-25-2005 09:40 |
| . . .yet another patchbay question | tlp | The Rack | 19 | 07-08-2004 13:56 |
| Transfering 4 track tape to an external tape deck | Michaelyu5 | Newbies | 8 | 10-22-2003 21:53 |
| ampex tube tape recorders | edcat | Other Equipment and Reviews | 0 | 05-07-2002 21:16 |
