Old 01-27-2000
BigDanStud BigDanStud is offline
Newbie
BigDanStud is on a distinguished road
Wink
Hey All,
I'm currently recording with Cakewalk Software on a PIII 450 with a Soundblaster Live! card, 128MB Ram, a Spirit 6-channel mixer, and an AKG C3000 large diaphram condenser mic. The problem I'm having is that when I record vocals, I'm having a hard time making them sound like part of the mix. They always end up sounding "seperate" or "removed", if you can follow that. Does anyone have any ideas, whether in the recording of or the mixing of the vocals and the rest of the tracks, that can help me get a better feel to my mix. Any ideas would be great.
By the way, I've been playing around with doubling the vocal track and delaying the second copy a very slight degree and then panning the first copy left and the second copy right. Any cool ideas along these lines?
Thanks in advance.
Dan
Old 01-27-2000
DALtune DALtune is offline
Senior Member
DALtune has a spectacular aura aboutDALtune has a spectacular aura aboutDALtune has a spectacular aura about
Wink
I would try messing with the effects a little bit, making sure you're getting the sound of vocals fitting in with the type of "room" the music is played in.
Also, depending on the monitors your using, that could add to the "hot" vocal sound. I have a set of BOSE 201s in the studio just to make sure of mixes.
Old 01-28-2000
dan dan is offline
Senior Member
dan is on a distinguished road
Wink
Hey Dan, this is an idea for your vocal mix. Its a really cool trick I just learned from Home Recording magazine. Its subtle but it really does sound cool.
OK Record a vocal track as you would any other. Record a second vocal track as similair as possible to the first (no matter how good you are it will obviously never be the same as the first. Thats the point). Now use your reverb effects on the second vocal and when your mixing down use the first vocals and the reverb from the second vocal not the vocals from the second. just the reverb. It sounds really cool especially when you start panning it around in different ways.
Old 01-28-2000
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
Wink
to make your vocals tighter in your mix try using a little
Predelay.
use short decay time between .5 and 1 sec. and long predelay between 100 and 250ms. This should give you a big sound but tight.
Be carefull with the reverb. misused, and chances it will make your vocals sound hazed.
Old 01-28-2000
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Cool
Big Dan Man:
I think you have received some great advice from Dark Star's Ed. Equipment of good calibre means a great deal when you want your vocals to come out in a specific manner.
I use the ART mic pre and I've found by experimenting that if I cut the input knob and increase the output knob and am in a good reverb room, I get some nice up front vocals which is what I like; maybe you remember the old Frank Sinatra vocals with Nelson Riddle's band; Frank was always up front and very very articulate; but, then, he had some great mics to choose from.
I also use the AKG 3000 among others. I have a question about that mic that maybe you or Dark Star can answer; there are three little ballpen switches on the back of the mic shaft and I have them all to the left. Is there a better way to position those switches?
Thanks, and keep twiddling the dials,
Green Hornet
