Old 01-25-2000
kristian's Avatar
kristian kristian is offline
1K Silver Member
kristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond reputekristian has a reputation beyond repute
Question
question one Using Art Dual Tubes as a pre amp for all applications, getting maybe 3 or 4 boxes and running staright to tape through those. Do you think you would get better results then going through the mixer to tape, or ART then mixer then tape? see because i was looking at the behringer multicomp and multigate, and one Dual Tube, but now im wondering if i should get the gates and/or compressor later and get more ARTs for better pres.
question twowhats the best signal path if there is going to be a compressor, gate, and an ART Tube in the path?
Old 01-25-2000
S8-N's Avatar
S8-N S8-N is offline
..|.. Part-time Antichrist ..|..
S8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond reputeS8-N has a reputation beyond repute
Thumbs down
If no outboard FX are used I'd run preamp to tape and bypass everything else.
I am guessing on this one but with the FX you mentioned I'd go preamp/compressor/gate but I don't use noise gates so I dont know...
Old 01-26-2000
kristian's Avatar
1K Silver Member
Thumbs up
ok so now we have recorded to tape through the ART Tubes without anything else, and i want to bring it back through the board for a final mix. Should i run the Gate, then compression before i eve get to the Mixing board? or else if i use Aux sends there wont be enough outboard channels.
Old 01-26-2000
PannyDeters PannyDeters is offline
Senior Member
PannyDeters is on a distinguished road
Red face
I ran my guitar amp out to an adapter and into the "sub ins" on my 414 and heard it through the headphones. I didn't record yet but I did get sound.
Anyone else have any experiance with this? Will it be cleaner?
Old 01-26-2000
kristian's Avatar
1K Silver Member
Thumbs down
using your guitar amp as a DI is a bad idea, it will sound like one of those guitars with the built in speaker that people used to get at the end of the 80's.... a.k.a.-crap.
tried it before with my 4 track.
Old 01-26-2000
Senior Member
Question
I have a Tascam 414 portastudio. If I got the ART tube mp, could I run it out to a 1/4 to rca adapater and plug that into my sub ins to bypass the mixer?
If not, is there ANY way to bypass the mixer?
Old 01-26-2000
kristian's Avatar
1K Silver Member
Question
are the XLRs on 1604 bal/unbalanced? if not, do the XDR preamps exist on the Line input, or since that is Line level does not need a preamp?
