VST Adapter doesn't work
When I download a VST and use the adapter for HS2, it doesn't recognize the plugin, why? What can I do to fix this?
- paul "Sometimes I think the surest sign that there is inteligent life in the universe is that none of it has tried to contact us" - Calvin (Bill Waterson) Proud member of the Ultra-Cool Brigade, with a desperate need for attention |
Did you register the new plugin by re-running the adapter program?
What dachay said...
You need to re-run the VST adapter to scan new installed VST before starting HS. Make sure adapter scans folder C:\Program files\Steinberg\VSTplugins, since most VST mostly installed there by default. ![]() Jaymz
Keep Rockin' and Rollin'...
... and I've heard of cases where people place the installation file or zip-file in the VST-folder. If you don't know it (I'm sure you do), you need to install/unpack it.
Two wrongs don't make a right, but two Wrights once made an airplane... |
That happeded to me. Must Unzip first, unless this is your first date.
i definately unzipped(tee hee) but it still doesn't recognize.
My vst's are just dll files, is everyone elses?
Yes, vst's are normally dll files. They should be placed in the same directory as your other vst files. |
i'm so sorry, but i don't understand what you mean by register
these were free downloads. I didn't install them I just exctacted them
That's pretty much how you install VST's. Bottom line, you still need to register them with the VST adapter if you want them to show up in Sonar. |
#12
Zona,
Each time you add a new VST you have to start the adapter. Open the adapter, hit next, hit add, go to the location of the file and hit next. Or just let the adapter find the file by hitting next each time. Same stuff said before but you were confused by the term "register." Once done open whatever you are using, sonar or cakewalk. |
#13
Seeing now that you have posted this question on another thread, you do know how to use the adaptor. So something must be wrong with the files you downloaded.
#14
| LINK to cubase vst demo download. (not sx) | ecktronic | Cubase User Forum | 3 | 06-24-2004 09:18 |
| will a 10,000rpm hard drive work better? | greggybud | Digital Recording & Computers | 8 | 03-30-2004 12:04 |
| VST wrapper for SONAR | Diatonic! | Cakewalk / Sonar Forum | 2 | 02-03-2002 10:53 |
