amp hum after mod - help!!
Okay, so I modded my amp (DSL401) - adding birght switches to both of the channels, removing a unnessasary capacitor that was limiting the bass response and added pin jack to the back of the amp so I could check the bias without taking the amp apart.
So i put it all back together and fired it up - no sound - then the sound faded in and there was all this crackling and stuff and then I watched on the 1/2W screen resistor burn up!! YIKES!! I looked around and found that I hadn't connected the HT to the output transformer - it was way in the back and close enough to the place it was supposed to go that it looked cennected when I double checked. Well, I was only running my amp with two tubes anyway, so I put the two tubes in the outer sockets. I turned it on and then I see lots of blue sparks in the tube that was in the socket when the screen resistor burned up. WOAH!! Well, I have like six spare tubes so I put in another set and everything seems ALMSOT alright.... One strange thing is that when I turn down the master volume all the way now, I still get a signal coming through the speakers.. there is also a permanant hum. It almost seems as if the master volume knob is more like a presence knob now because the volume doesn't change as much as the tone does - crank the volume and it get bassy, turn it down and it gets thin... I am assuming that somewhow somewhere the signal from the phase inverter is sneaking past the master volume and into the grids... one more odd thing.. I was cheking the differences in the circuitry between the two tubes. and noticed that when I connected the lead of my multimeter to pin 2 of the leftmost tube there was a loud pop. When I connected it to pin 2 of the rightmost tube there wasn't a pop. This was the same for the inner sockets that contained no tubes (including the one that had failed previously) The left one popped and the right one didn't.. anybody have any suggestion as to what might be the problem here? It is baffling me!! Thanks for any input.......... |
Thats gotta suck. I would have shit myself if I saw that.
Well, that is why even amp and guitar techs will make you sign a waver of liability. ![]() Quote:
I have that with my Super Reverb and my ProJr. Its very faint. Almost unnoticable. I figure its nothing. |
Assuming that you replaced the burnt resistor, you need to go through everything that that resistor was attached to and on up the line. When 1 component burns up, it normally takes a few more with it. It isn't obvious because the others might not have completly burnt up.
You should take it to a tech, you might have screwed up the choke or one of the transformers.
well.....
Ah, its wasn't so bad... That's the beauty of tube amps, you screw up one socket, so you plug it into the other one, you screw up a tube so you put another one in... no biggie....
about the hum.... I think I have traced it down to somewhere in the master volume circuit. I did some poking around with a multimeter and found that the resistance from the grid resistors to ground on the leftmost cokets varies between 7-10 Mohms when I vary the Master volume. The right ones vary from 25K-200K. Since the master volume is a 200K pot, my guess is that somewhere between the bias circuit and the grid resistors there is an open circuit, bad solder joint, or something... I won't have time to track it down for a while, though... I measured the bias at the grid resistors and one side is reading -12V (left most tubes) and the other is reading -17V, so it seems it would have to be in there somewhere... perhaps the master volume knob is bad... hard to say, but I'm glad I was able to track it down..... The good thing is that while I have it all apart I can take out the bright cap I put in because it is WAY too bright- I put in the factory spec 470pF cap - I realized yesterday that the guy I bought my amp from had already modded it to a 100pF cap, which sounds MUCH better!! No wonder people are always dissin this amp!! I can't stand the 470pF cap in there!! I'm going to install pin headers where all the "bright" cap go, then i'll be able to just plug different values of caps in and find what I like and then wire that one to the switch.... Oh, yeah... I just ordered a digital camera, so I'll put the bad tube back in my amp long enough to get one good picture of the tube sparking inside, maybe even some video.... You might all like to see that - especially if it is in someone else's amp!! anyone else have any input? |
I have some good reputation points points waiting to be given to you if a pic and/or video pops up. ![]() |
pheeww!!
For what its worth, I have isolated the problem to the master volume circuit - probally a bad solder joint created from stress placed on the pot during the modification.
YES!! You will be seeing PICs of a tube throwing sparks!! and maybe some video... as soon as my camera comes.... Quote:
Hey gusfinley!
I also have a DSL401... can you tell me, did removing the cap bring more bass response on the clean channel, the OD channel, or both? And can you tell me which cap that is and how to remove it? |
You might want to research this a bit more first. If you don't know how to remove a capacitor then you don't know enough about circuits to work inside a tube amp. http://www.geofex.com/tubeampfaq/tube_amp.htm#Section0 You could die or get the living shit shocked out of you if you don't know what you are doing.
For your hum problem, I'd guess that somehow you changed the grounding scheme of the circuit, and you've got a ground loop somewhere. Maybe one of the switches you added
The cap you removed, did you need it to block DC? Perhaps you should upgrade the cap with a higher quality and larger value rather than just leaving it out? |
#12
http://www.webervst.com/vstbbs/bbs.html
click on the blue button, top left (AMPS) http://www.firebottle.com/fireforum/...irst_days_old= Select a forum, Mods and Tweeks http://www.vintageamps.com/plexiboard/index.php Someone in these message boards should be able to help.
My Gear List |
| D@mned amp hum! How do i get rid of it? | octoruss | Guitars and Basses | 16 | 05-10-2004 23:53 |
| Amp hum...Broken tubes?? | coolasvanillaic | Guitars and Basses | 5 | 03-08-2004 17:03 |
| Lexicon 284 Class A Recording Tube Amp | Pearldiver | Free Ads for Music / Recording Equipment | 2 | 08-02-2002 19:30 |
| still massive hum in setup! | midge | Studio Building & Display | 1 | 07-24-2002 01:48 |
