Clean noisy pots
I think my old Tascam m216 need cleaning because some pots are a little bit noisy. Anybody have a few tips? Can I use a regular contact cleaning or a specific product? Is it worth the trouble to clean the pots or is it risky? Is it possible to completely wipe out the noise
?Thanks |
This stuff is great for all rotary and sliding pots.
Even NASA uses the stuff. http://shopping.netledger.com/s.nl/c...LOlQzNp65In0__ Cheers! ![]() |
I've had great results on my M-216 and M-208 using Radio Shack TV Tuner/Control Cleaner & Lubricant, believe it or not.
However, CAIG is definitely the best stuff and cheaper per ounce than Radio Shack products. Try compressed air first-- sometimes that will do it without having to introduce any chemicals. Whatever you do don't use a solvent or orange-based stuff. It's kind of a pain. You have to turn the unit upside down and take the bottom panel off. Then just spray a very small amount in the tiny opening on each pot. -Tim ![]()
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
Thanks
Many thanks to all reply, it's very helpfull.
If you're uneasy about spraying the internal parts, sometimes you can get away with removing the knob and just spritzing a little on the shaft where it goes down inside the housing. Put a rag around the area to keep the mess to a minimum, and you must crank the shaft back and forth several times to help work it in. This doesn't always work but sometimes, in a pinch you can save time.
"Is this thing on"?????? |
| DMP3 Noisy! | LooneyTunez | The Rack | 6 | 06-27-2003 10:51 |
| Scratchy pots? | esactun | Other Equipment and Reviews | 8 | 05-13-2002 13:48 |
| Hush boxes for noisy equipment | skippy | The Rack | 0 | 10-25-2000 09:51 |
| noisy strat & noisy pedal | lazyboy | Guitars and Basses | 2 | 02-18-2000 16:05 |
