OK, Im reeeeeally P!$$ed off now. I've had my US Strat Plus for 17 years now and recently, say within the last 4 years, I've been going through strings (especially 0.26 D string) at a rate of every other gig. Sometimes I'll string it completely on the Monday, gig on the Wednesday, gig on the Thursday (break a D string) and re-string on the Friday, ready for the weekend. The bridge saddles are those US powder coated type. It seems like the strings are cutting grooves into the saddles. I remove all the burrs with wet 'n' dry everytime I re-string. I have replaced the saddles with new ones (the same type) but to no effect.
So, would replacing my bridge with a vintage US strat bridge with the nickel saddles cure my problem?? (Yes I know the vintage one has 6 screws but it'll be worth it if it works.) Any ideas, help or suggestions are welcome. (and no Im not going to buy a Les Paul!!)
Twing - Twang - Twang - !SNAP! - "Bollocks!" |
i had exactly the same problem - and most of the time it was the d string on my american series strat......i play with quite a heavy style and it was pissing me off and my band even more! since i've got a framus haven't had half the string breakages - but still need to fix the saddle - not really sure what the options are though....
Oh thank the lord! I thought I was the only one in the world! Theres a couple of options, replace the saddles with graphite ones etc but I want to maintain the Fender look. So I was hoping the vintage saddles don't break the strings as much.
i would get graphtech saddles.
Now if I said I had tried the Graphtech saddles and it broke the same string in the same place, would you say it was the string at fault. Im using Ernies 10's
Graph tech is making new saddles that are chrome with an insert of graphite at the contact points. That way you can keep the chrome theme of the bridge intact while getting the benefits of graphite saddles.
They also make graphite string trees and nuts. http://www.graphtech.com/product_dis...nd=StringSaver (scroll down until you see the FerraGlides) And... yes, it could be your strings contributing to the problem. I have noticed some strings last longer for me than others. For instance, I usually use D'Addario 11s but I have recently been experimenting with DR 11s. The DRs seem to last a little longer (not ALOT longer, but definitely longer).
Talk Nerdy To Me. |
Same issue for me...one of the strings on my strat keeps breaking at the saddle. Upon inspection, the string had worn a groove in the saddle, which was undoubtedly wearing the string the wrong way.
I visited the graphtech website, and they have what I apparently need, but it costs $60 for a set. A couple of questions: 1. Is Graphtech the only company that makes graphite saddles? 2. Can you buy Graphtech anywhere besides the website? 3. Besides less string breakage, are there any other advantages to graphite? I could replace the saddles for cheaper by going with a stock replacement (vs. graphite), and have maybe 15 more years of trouble-free playing before they wore out again, if there are no other advantages. |
Yer same peroblem here, i have a very "hard hitting, funky style!" but i get through strings at a rate too and my strat and tele(less on the tele). Anoys me!
2. Ebay. Don't know of anywhere else. Again, don't quote me. 3. Supposedly (I'm no expert), the graphite helps the guitar stay in tune-- especially when using heavy tremolo. The theory is that the graphite provides more lubrication and therefore reduces friction. I don't know how much difference just the saddles make in this situation. I suppose the ideal setup would be graphite saddles, graphite nut, and graphite string trees. Anywhere there is contact with the string will produce friction-- leading to tuning/breakage problems.
Talk Nerdy To Me. |
Many years ago when I still used the tremolo arm on my strat I would actually put a tiny bit of oil under each string where it hit the nut. It seemed to make all the difference in the world. I could dive bomb the pitch to the floor and it would still come right back to pitch.
_________ - Ritual |
#12
Yeah, I've seen something similar recommended by various people.
However, the lubricant was graphite powder. I've even seen people recommend filing/sanding the graphite lead from a pencil and putting the powder in the nut/saddle slots. Same concept... different lubricant.
Talk Nerdy To Me. |
#13
Maybe you could just lube the saddles and nut with graphite (from a pencil). It works for me, I break a string every once in a while. You could also change to a lighter pick to counteract that heavy picking.
sloanstewart.com |
#14
OK, Im fitting my Graphtech saddles tonight, restringing with Ernie Ball 10's and we'll see what happens. Im gigging all weekend so if it's gonna break it will then. If it does my 17 year relationship with my strat will come to an end as I calmly launch it from the van window into the on-coming traffic.
#15
do they have the graphite saddles for an LP?
i am having the same problem
- paul "Sometimes I think the surest sign that there is inteligent life in the universe is that none of it has tried to contact us" - Calvin (Bill Waterson) Proud member of the Ultra-Cool Brigade, with a desperate need for attention |
#16
Yes they do, and when you put them on you will have no more stringbreakages at the saddles, also your intonation and sustain will improve, only a little bit, but yes, you will notice it.
LeeJ, I am sure the grahptech saddles will do their job, so no need to fall out of love with your strat Cheers Eddie |
#17
Every time I've used them, I get a string break. The cheap house brand I buy lasts longer than those things.
sloanstewart.com |
#18
I changed to d'addario and they lasted probably 2 weeks or longer. then after about a year i changed to gibsons and i've only broken i think 2 strings since. so in the last 3 years i'm pretty positive i've only broken at the very max 2 strings.......and i know that one of those was because i had a brain fart and was turning the wrong tuner and kept turning it til the string broke and smacked me in the face. I don't know if a second time actually happened, i'm just adding one because there's a chance i forgot one. i'm not saying that the gibsons are the best, because well, even though i haven't tried anything but the 3 i mentioned before, i'm sure they aren't. BUT i am saying that there is a VERY good chance that you need to try a different string brand.
This place is garbage. |
#19
Which Gibsons are they then? Im gonna try a string change. If it cures my problem have a look on e-bay soon. Theres gonna be a 20 packets of Ernies on there soon!!!
#20
I usually keep them on 4-5 months with no problems or until the plain strings get REALLY rusty & crusty. But! They're coming out with new strings that are anti-rust. Can't wait to try those!
sloanstewart.com |
#21
I had the same breakage problems with mt Strat. when new, it was a nightmare so I removed each saddle and filed them smooth using small die files. That was in '86 and I very rarely break strings.
It looked to me like a casting fault, the mold finish was OK but not good enough, whatever, the filing fixed it. |
#22
I have a vintage strat that I never break a sring on. I have a mexican strat that I break the little E on just about everytime I giged with it. I have replaced the saddle...still broke strings. I think the bridgeplate or the block may be the problem. I keep that strat tuned in open E now and use it for slide only. If I ever start using it as a main guitar again, im going to take the entire bridge assembly apart and file the edges of the block holes, and file the bridgeplae holes into a longer oval pattern, so it doesn't make contact with the strings.
File every edge that touches your string and, by the process of elimination, you will fix the problem. |
#23
By the way...
I was in my local ACE hardware store last night. I picked up a tube of graphite powder for $1.50. I'll be lubing up the nut and saddles on my LP style guitars. http://www.acehardware.com/product/i...entPage=search (the link is for a 12-pack... don't let the price scare you).
Talk Nerdy To Me. |
#24
The saddles on my Les Paul get worn from the wound strings and I used to snap a D string once in a while. The winding on the string cuts a spiral pattern into the saddle. You have to look really close to se it.
I use 1200 grit sand paper. Just fold it once or twice and polish the notch in the saddle till it looks smooth. Also rounded over the front of the saddle a little where it comes to an edge. I use pencil lead(graphite) to lube the saddles. Just tune to pitch, Carefully lift each string out of it's notch, and twirl the pencil point in it. it will grind enough graphite to fill the notch. After analyzing my playing style, I came to the conclusion that my pick was a little heavy for my style and string gauge. I switched from Fender medium picks to dunlop tortex (the orange ones) I'm not sure of the gauge, but they're slightly lighter, and they last a lot longer too. I use D'addario 10's. I've pretty much eliminated the problem completely.
"Is this thing on"?????? |
#25
my LP is an offbreand copy, which ones should I get?
| For the love of God, SOMEONE help me tune my 12 string guitar! | Mike Richardson | Guitars and Basses | 20 | 08-22-2007 11:09 |
| Fixed my computer-life is good!! | RICK FITZPATRICK | Studio Building & Display | 11 | 10-12-2004 14:48 |
| Guitar intonation | mentil69 | Guitars and Basses | 30 | 03-30-2003 11:50 |
| Help please - Strat string tightness | gtds | Guitars and Basses | 24 | 11-26-2002 14:39 |
