Old 02-03-2005
Bigsnake00 Bigsnake00 is offline
Force of Nature
Bigsnake00 is on a distinguished road
What is a TS cable?
Is a ts cable just a regular guitar cable?
Old 02-03-2005
Dracon's Avatar
Dracon Dracon is offline
Force of Nature
Dracon is on a distinguished road
Basically its a mono cable with a phone jack at the (TS = Tip Sleeve). Stereo cables with 1/4" Phone Jack is a TRS (Tip, Ring, Sleeve).
Thanks,
Dracon
"She's a rich girl.."
Hall & Oats
Old 02-03-2005
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
No, but a regular guitar cable is a ts. The TS stands for Tip/Sleeve, which indicates an unbalanced cable. A TRS is a Tip/Ring/Sleeve, balanced cable.
There are other cables that can also be TS or TRS.
Originally Posted by 60's guy View Post
You win.
Old 02-04-2005
gordone's Avatar
gordone gordone is offline
1K Silver Member
gordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond reputegordone has a reputation beyond repute
Lightbulb
A TRS cable isn't really a "Stereo" cable. It can be used for stereo, but it can also be used for a balanced connection. Basically it's a TRS cable
Old 02-04-2005
Dracon's Avatar
Force of Nature
I don't disagree with you. What did I say that was incorrect? I understand the concept of the balanced cable. Tip (positive - left), Ring (Negative - right), Sleeve (Ground) which is used in a stereo connection. You can also use two TS cables for a stereo connection.
Oh! I see, you are saying that TRS is not only a stereo connection, but can also be used for a balanced connection. Yes, thank you! I didn't mean to confuse anyone by my statement. However, technically (even if you do record mono) the signal running through the TRS (balanced cable) will be a stereo signal (meaning one signal on the Tip & one on the Ring - even if it's the same signal).
Anyway, short answer is yes. I concur and fully agree with you because you are correct.
Thanks,
Dracon
Hall & Oats
Oxygen Free Mic Cable Question nostrovia Microphones 12 08-10-2009 07:01
Cable Basics - a primer for newbies homerecor Newbies 1 03-04-2004 06:45
The best quality cable? Mongoo Other Equipment and Reviews 6 02-18-2004 08:53
Cable killer strikes again.... RICK FITZPATRICK Analog Only 19 10-24-2003 14:54
Belden BL-1800F Digital Cable. Sources? DigitalDon Studio Building & Display 3 05-29-2003 14:48
