Old 02-01-2005
sonis_youth sonis_youth is offline
Newbie
sonis_youth is on a distinguished road
Behinrger V-amp Pro
I'm thinking of buying a V-amp pro, but I'm a little confused aboud how to connect it. I want to record guitar onto an Tascam dp-01, can I just plug my guitar in the input of the V-amp and from there to the line in on the recorder? Thanks
Old 02-01-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Yes, that's the correct set-up for direct recording from the V-Amp Pro.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 02-02-2005
Newbie
so I won't be needing a guitar amplifier or mixing panel or whatever?
Old 02-02-2005
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
The VAmp is a "guitar amp", which you in essence would be running direct to your recorder (vs. mic'ing a speaker cab)
Old 02-02-2005
Ed Dixon Ed Dixon is offline
1K Silver Member
Ed Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond repute
That combo will work fine. The V-Amp is a preamp, which is what your line in connection is looking for.
Ed
Old 02-02-2005
Newbie
ok, thanks
Opinions on using Crown amp to replace my Roland amp warble The Rack 3 08-27-2004 18:52
Setting up my headphone amp justwantyou2kno The Rack 2 01-27-2004 00:24
overloading:p/u vs amp cstockdale Guitars and Basses 1 07-23-2003 18:00
Yorkville YSM1p vs Yorkville YSMi + power amp ambi Mixing / Mastering 25 04-01-2003 12:40
POD Pro into Dakota/Tango DAW...HELP!!! wyanes The Rack 0 09-11-2000 21:10
