Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 01-23-2005
earworm's Avatar
earworm earworm is offline
it might be true...
earworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond repute
what kind of solder do u use for soldering mic cables?
its time again to solder a bunch of new cables,
exactly a year ago i made me about 10 cables with real Cheap stuff,
some cables even broke down during those 12 months...
now i need more cables,and i want to improve my quality,
so i'm hunting for 50 meter canare or mogami cable,
and a load of neutrik xlr connectors
shouldn't be too hard to find this, but i wonder,
i'm using this old soldering machine that used to by my dad's,
and it still has "pretty" old solder wire in the box...
so the QUestion:
i wonder, will the kind of solder wire i use have effect on how easy i can solder all my parts? or will Cheap be good enough? (any brands or types u want to suggest? like thins without lead or something...?)
+ is Neutrik thé brand to choose, or is there stuff that is less expensive and does a real nice job.?
cheers,
earworm
...listen...
Old 01-23-2005
Dot Dot is offline
1K Silver Member
Dot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond reputeDot has a reputation beyond repute
earworm, I've got a couple articles on soldering.
Soldering 101 for Recording Studios - Part 1
http://www.digitalprosound.com/2003/...ldering101.htm
Soldering 101 for Recording Studios - Part 2
http://www.digitalprosound.com/2003/...soldering2.htm
Radio Shack's one of the best places to get the right kind of solder. Something like High-Tech Rosin-Core Solder .050 diameter in a 1.5 oz spool.
A lot of the lead-free solder is for art projects and not electronics.
A good place to order cables and connectors is http://www.markertek.com
Neutrik connectors are solid and I'd recommend them - also Switchcraft. Raw cable by Mogami, Canare, Belden.
Good luck with it...
Dan Richards
The Listening Sessions
Yackin' about gear and recording techniques at Studio Forums.
Old 01-23-2005
earworm's Avatar
it might be true...
ok, thanks,
and ehm, i didn't see it while i went trough a few "soldering threads",
so i wanna ask it now: when i buy mic cables, what does
.150 and .255 mean?
is that the thickness of the wires ?
cheers
...listen...
Old 01-23-2005
arcaxis's Avatar
arcaxis arcaxis is offline
Force of Nature
arcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond repute
Besides Radio Shack, here's a good online place to get solder, tools and other necessities. They quite often send out flyers with some pretty good sales and usually you can get a roll of solder a buck or so cheaper than their normal catalog price.
http://www.partsexpress.com/
Solder page....
http://www.partsexpress.com/webpage....up_ID=361&SO=2
Looks like Dan covered the ins and outs of soldering in the 2 articles he wrote so there's not much more that can be said about that.
One thing to note though, is that when you handle solder, wash your hands after, don't eat or smoke while working, and don't use your mouth as a third hand to hold the solder. The lead in the solder can cause some health issues and was one of the prime reasons plumbing solder no longer has lead in it.
And don't burn the fingers !!!
Old 01-24-2005
In Tune Audio In Tune Audio is offline
Dedicated Member
In Tune Audio is on a distinguished road
When I first started soldering my own cables, I used a really cheep solder. It was a pain to work with. It was very thick, and I kept getting cold solders because I just couldn't get the flow I needed. Bought better solder, and it was incredible, how much easier, and quicker it became to make the cables.
I love my mogami. I've been using neutrik connectors, and like them alot, although they are the only connectors I've used thus far.
Old 01-24-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
In addition to what they said, you'll probably want to use flux as well, makes solder flow and stick a lot better. I like to use the stuff that comes in a pen. Don't use the lead free stuff, it has a higher melting temp, which will just complicate things for you.
Old 01-24-2005
Le Basseur Le Basseur is offline
Junior Member
Le Basseur is on a distinguished road
If you're really picky,you might try a solder having 2 to 4 percent silver (WBT,Audio Note and other brands).
...though,this stuff is pretty expensive...but it gives the neatest soldering points I ever made!
Good luck,
Old 01-24-2005
paddyponchero's Avatar
paddyponchero paddyponchero is offline
Force of Nature
paddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to allpaddyponchero is a name known to all
Cheap solder usually uses a very poorly refined / contaminated rosin flux which produces clouds of noxious smoke, just buy a decent coil that has a no-clean flux.
Under the future regulations on the Restriction of Hazardous Substances (2006 in Japan, 2007 in EU, US later) we'll all have to get used to lead free solder, now might be a good time to start
It is usually not the soldering that fails, the wire usually cracks due to lack of sufficient clamping and support in the connector. I recomend Neutrik connectors.
Old 01-25-2005
Marik's Avatar
Marik Marik is offline
Pro Microphone Design
Marik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond reputeMarik has a reputation beyond repute
I use a silver solder found here:
http://www.welbornelabs.com/solder.htm
Go down to welbornelabs silver solder. Very nice, professional looking joints, which are stronger than regular one. Flows very nicely, and leaves little residual. Make sure to read a solder primar on very bottom.
$28 a pound is worth every penny. I have been using the spool for over a year, and I solder... I mean it--a lot.
Old 01-25-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Just to pick nits, with regard to the soldering not failing, that's only true if you know what you're doing and are careful. Many a cold solder joint fails prematurely. That said, any decent solder joint is unlikely to fail before the wire attached to it.
Personally, I use lead-free solder whenever I can, for safety reasons. This is particularly a good idea if you have any young kids, but it's not a bad idea in general. There are electronics-quality lead-free, rosin core solders out there, but you have to hunt for them, and sometimes traditional lead solder is more convenient, particularly when soldering to PCBs and silicon devices where overheating is a concern. (Lead-free solder typically flows at a higher temperature.)
However, if all you're doing is soldering cables... I'd say use the lead-free stuff, if for no other reason than because if it ever ends up in a landfill, you probably don't want lead leaching into your drinking water.... Just my $0.0198 (adjusted for inflation).
Help with Mic Cables zackformula Microphones 37 08-10-2004 15:21
mic cables on ebay? RKID001 Microphones 5 05-08-2003 06:09
mic cables, which ones? Falopo Microphones 3 03-20-2003 13:13
Best deal on GOOD mic cables here... tubedude Microphones 23 09-15-2002 03:32
mic cables o-ron Microphones 6 06-13-2002 19:20
