Got a new subwoofer. Please check my mix.
http://www.armlock.com/idea2.mp3
Its not a complete song but I am experimenting with my new subwoofer (M-Audio BSX) with my Wharfadale 8.1 monitors. Before I got the sub i had nasty low end issues in my mixes. Hopefully theyll be better now. Does anyone else feel they get better mixes (especially in the lows) with a subwoofer? |
yeah sounds great with a sub
Without one it lacks bass. I burned as is to CD and listened in the car and the bass is really burried. Turn your sub down. Listen to commercial CDs and get the ballance right first. Training your ear to a new system takes time. I suggest 20 hours minimum listening to commercial CDs to get acustomed to your new expanded bass depth. Remember the real world people witn no sub that's gonna listen Alec |
Great sound, but I agree that it lacks some bass.
I like the song as well, it's really cool and relaxed. What kind of guitar amp did you use? |
ok, im going to turn it down. thanks!
thats a stock blues jr. with a gibson les paul jr DC faded with P90s that i picked up new for $599 a couple of months ago. i love the sound with the blue jr. no pedals. Last edited by Rickson Gracie; 01-21-2005 at 21:40.. |
ok, i lowered the sub and i remixed it. please let me know if its better. thanks!
bass is still very buried.
it sounds like the problem is that all your bass sound is in the less-than-80Hz range, where most consumer speakers are very weak. you need to EQ to balance your bass harmonics so that it sounds right regardless of whether or not the listener is using crappy speakers. here's a good idea: occasionally check your mix by putting an 80Hz highpass over the whole thing. if the mix balance changes considerably, or you can't hear the bass anymore, you've got problems. the mix should sound the same, you just shouldn't be able to feel the bass in your chest anymore. |
What is your room like? Once you add a sub, you really have to pay attention to room acoustics.
thanks guys...here is a nother try at the same mix.
http://www.armlock.com/pb2.mp3 I adjusted the angle and distance of the speakers and adjusted the crossovers on the sub. thanks. by the way the sub is up againstthe wall sideways. i wonder if thats an issue. |
thanks bleyrad for that tip. i am using pro tools le. i guess i would just make a master fader track and add the eq plugin to that and then occaionally check that with that track?
BAD thing to do man! |
my wharfedale pro 8.1s have no bottom end i need to make up for it. my mixes were very bass heavy.
why wouldnt i be able to have a flat sound with a sub? if it just fills in the whole of the bottom end it shouldnt matter...right? i need to have some sense of bass. its part of the mix too. i am in the process of using an spl meter to hopefuly correct some problems. as long as the lower frequencies are as flat as the rest of the frequences i dont see the problem. am i wrong? |
#12
You can use a sub as mentioned above your just going to have to work with the volume of it. From what I'm hearing in your mixes you need your sub set where you only know its on when you turn it off. You just want bass support not "quad" in your studio. You can use your DAW to RTA your room and can pick a Behringer ECM8000 referance mic for around $50.00. There are cheap RTA shareware programs all over the web if you don't have on in PT.
The most popular HR member - just do a search
#13
yes the bass is definitly part of the mix, but I think you need to understand the meaning of a "flat" sound when you mix. yes most studios use 3 different sets of speakers. You definitly want to hear your music through different types of audio players. car. home stereo.ipod/wlakman. whatever. it will sound different on each one, but the trick is to get the mix to sound the best you can on all. Throiwng a sub-woofer into your gear for mixing down, is personally something ive never seen or heard of. but to each his own
#14
#15
I have been googling and searching to no avail, but if I remember right, a good rule of thumb for setting up a sub in a system is to run pink noise through one monitor and the sub and shoot for a 6db difference at your listening position. For example, if you have 85db with both on, and drop to 79 db with the sub only with the SPL meter in the same spot, you'll be pretty close to where you need to be.
#16
I hope you don't take this the wrong way, but before you paint with such a broad brush, you may want to do a little research. We have thousands of users, using our monitoring systems for tracking, mixing & mastering of both stereo and 5.1 audio (music, post, multi-media, TV etc). These include high-profile users, such as Skywalker Sound, (50+ systems), ESPN, Emil Berliner Studios (Mastering SACD and DVD/A for Universal Music / Deutsche Grammophon, Decca, Phillips etc), Tom Lord-Alge - three-time Grammy award winning mixer for such artist as Avril Lavigne, Blink 182, Switchfoot, Marilyn Manson and Weezer, among many many others. All of these users use systems that include a subwoofer, which is an integral part of all of our monitoring systems. Having said that, adding a subwoofer to "any old speaker" can be tricky. The key is proper system design, that doesn't treat subwoofers as an after thought. Additionally, what is also critical is proper system calibration. For more information visit - www.abluesky.com/fullrange (our 2.1 / 5.1 system design philosophy) www.abluesky.com/calibration (calibration information along with test signals) www.abluesky.com/subplacement (sub placement guide) www.abluesky.com (user stories, forums and other information) I hope some of this helps... Cheers! |
#17
Thats interesting. im going to try that. thanks. |
#18
Your bass is fine by the way. Not distinct but EQ was about right.
This is just a test |
#19
#20
A subwoofer is mandatory for nearfeilds that are 6 inches or smaller. There is no way to accurately mix under 200Hz without one.
I would say if you have 8 inches and up, you could do without one, but not all speakers have a detailed low end so you have to pick and chose carefully. Also, go for front ported speakers and you will be reducing your need for a sub.
This is just a test Last edited by Middleman; 01-25-2005 at 21:51.. |
#21
#22
Try using our test tones. They are used by many people, with all kinds of monitors, with great success. www.abluesky.com/calibration Cheers! |
#23
Yeah if the speakers are big enough then there shouldnt be any real need for a sub in my opinion. If award wining mixers use them there must be something good about using them, but if you also have accurate large speakers with a properly treated room then your jamin anyway.
#24
thanks bluesky!
#25
Pascal Sijen, thanks for the link. I used your tones and calibrated my monitors tonight. Wow! What a difference. I was running my soundcard at too low a volume and my speakers too high resulting in a mirky image.
After running the tests at your site, well, I feel like I'm mixing on new monitors. Thanks.
| Some Thoughts about "Better", "Best", and Mic Recommendations | Harvey Gerst | Microphones | 156 | 06-04-2009 07:27 |
| Using Quick Mix techniques | crawdad | Mixing / Mastering | 12 | 01-02-2007 10:04 |
| Check the Mix | soundzxtreme | MP3 Mixing Clinic | 1 | 05-24-2002 20:16 |
| Hello. I posted this into wrong places, but check out my mix. :) | spaymikko | MP3 Mixing Clinic | 2 | 11-19-2001 09:31 |
| Low mix on CD | Uladine | Roland, Boss, VS Series Forum | 2 | 09-07-2001 22:43 |
