Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 01-20-2005
paresh's Avatar
paresh paresh is offline
Dedicated Member
paresh is a jewel in the roughparesh is a jewel in the roughparesh is a jewel in the roughparesh is a jewel in the rough
compression/normalization
Does anyone ever use compression + normalization for vocals? Between the two, I hear better results fr normalization. thanks
Paresh
Old 01-20-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Normalization is nothing more than an automatic gain setting tool. You get the same results as raising a fader, so I'm not sure why you think it's "better"........
Old 01-20-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
When you are using compression, you will usually use "make-up gain" to bring the mean signal up. But, as the bear says, normalization does not play a role.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 01-21-2005
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
As Bruce and Scrubs mentioned, the reason why you feel normalization is probably sounding better is that possibly you are not using gain makeup in the compressor, but just cutting down on the dynamic range.
The pupose of the compressor (at least the usual purpose) is to reduce the dynamic range by lowering the level of the audio by a set ratio and threshold. By doing that you can raise the overall volume to create a track with an overall louder average (RMS). This is where you need "gain makeup" to makeup the difference between the original signal and the compressed signal.
With normalization (in the traditional sense) the software goes through the entire track finding the loudest value. If it's less than 0 dbFS (digital peak) it will raise the volume of the audio so that the entire track is raised proportionally to get as close to the peak as you tell it to. This does not decrease the dynamic range, but as Bruce mentioned just raised the volume of the track by the preset amount. If later you decide the vocal are too loud and reduced the volume you acomplished nothing other than to add distortion to your track.
Now if you're saying that you don't like the sound of compresion, that's an entirely different topic I'll need my third cup of coffee of the day for ...
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 01-21-2005
ryanlikestorock ryanlikestorock is offline
Force of Nature
ryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to behold
I think it's about time the function of "normalization" be taken out of all digital editing systems.
Old 01-21-2005
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Yeah, but then what would we have to laugh at newbies about?
Old 01-21-2005
I don't know about that... it's just another tool after all, a different mechanism to apply gain. The problem is not the tool, but people's lack of knowledge in its use!
After all, a screwdriver or hammer could be considered pretty useless until you know what/how they're used!
Old 01-21-2005
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
i had a guy call me today and ask me if he could bring in his normaliser and put it into my signal chain just so see what it could do.
"Sure" I say, "but I have to charge you for an hours block."
"thats ok", he replies.
I ask "do you have pretracked mixes that you need normalized?"
"pre tracked?!?!?!" he replies "I like the distortion effect on it"
After much discussion about what the f*** he was talkin about, I came to realize that he did in fact have a normaliser, set 10 times too high, so it constantly clipped everything.
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen
Old 01-21-2005
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Ok, here's the deal. It's renamed 'Abnormalization'. That way maybe folks won't just naturally flock to it like lemmings.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 01-21-2005
Thumbs up
Lemmingizing....... I like it!!!
Old 01-22-2005
The only use I've had for normalization is ages ago making keyboard samples.
  #12
Old 01-23-2005
Definitely one good example of it's proper use. Normalization (IMHO) should be the final step and used in situations where you want to bring up the overall volume of a mix (or source) to a maximum value without changing the dynamic range. Normalization isn't bad, just misued.
There are also other types of normalization that behave differently and act more like limiters and compressors. For example the Finalizer has a "normalization"' function that works this way and Sound Forge I believe also has as similar normalization function that will allow you to automatically set the RMS level.
Tom Volpicelli
MySpace:
