Synching Roland 1880 to Audition
Im dumping tracks recorded on a Roland 1880 into Audition via a Delta 1010LT. The Roland only has 8 direct outs that I can utilize, so I have to make two passes for the dump into Audition. With Audition is it possible to control the Roland via Midi, so when I do my second pass, everything locks up? If so, how the hell do you do it?
Here a douche, there a douche, everywhere a douche douche. |
Unfortunately, no.
Auditions MIDI capabilities are quite limited to playback and editing of MIDI files. There is no way to utilize Audition as a Master to the Roland as a slave... However (I used to use an 1880) if you save all the tracks from the 1880 as solo tracks, full length of the recording in wave format, you can dump them the long, hard, and painful way... ![]() It's time consuming, but without the CD-R plugin in, or a zip drive for the Roland to the PC, there's no easier way to tranfer those files.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
It takes a tad more effort, but I can get them to line up manually later. Thanks for the info, now I won't waste the time trying to get Audition to control the 1880.
You should be able to set up MTC sync between the two.
Audition MTC/SMPTE slave. Set midi in port for sync. Pick 30fpsND. Roland VS, MTC master 30fpsND. Connect VS midi out to pc midi in. Set AA tracks into record, should say waiting for time code. Hit 1880 play, all should start together. I used to do this with a humble VS840, so it should be possible with the 1880! That said, it really is both better and more convenient to directly transfer with .wav files if you can. If it means making a CD-r, then you've got a backup of the tracks in the bargain!
As one door closes, another one slams in my face. |
Thanks Jim, I'll try that.
| Upgrading to Audition 1.5 | DigiDunce | Cool Edit Pro / Adobe Audition Forum | 5 | 11-26-2004 02:17 |
| Need help with Cool Edit/Adobe Audition recording | Cherub96 | Cool Edit Pro / Adobe Audition Forum | 5 | 10-27-2004 19:46 |
| Audition 1.5 tryout now available | ozpeter | Cool Edit Pro / Adobe Audition Forum | 12 | 07-08-2004 05:42 |
| behringer ada8000 + event ez-8 + adobe audition = HOW??? | nme666.com | Digital Recording & Computers | 9 | 04-05-2004 09:27 |
| Well it's here.... ADOBE AUDITION! | scottboyher | Cool Edit Pro / Adobe Audition Forum | 11 | 07-12-2003 06:41 |
