Go Back   Home Recording > General Discussions > Digital Recording & Computers
Reply    Audiofanzine Computer-music Computer-music News Computer-music Medias Computer-music Tests Computer-music Articles Computer-music User Reviews Computer-music Classifieds Ads
Old 01-15-2005
Cheeky Monkey Cheeky Monkey is offline
Dedicated Member
Cheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the roughCheeky Monkey is a jewel in the rough
PC Networking
I recently bought a new (used) PC (Windows XP) that I want to dedicate to recording -- no internet connectivity. I know many use their recording PC also for the internet, but I've decided I just don't want to do it that way. For the internet, I'll continue to use my older P2 (64mb ram, 400 mhz, 10gb HD, Windows 98). I'd like to network the two together, share one monitor, and use the P2 to download plug-ins, etc. that I could easily transfer to the recording PC.
I'd appreciate any advice, including recommendations regarding cabling or whatever that I'll need. One thing I'm wondering -- can I even do this where one PC is running Windows XP and the other, 98? I could be wrong, but I suspect I can't upgrade the P2 to XP (???). If I can't network, I s'pose another option is to buy an external CD burner for the P2 and copy the plugins over to the XP machine.
All advice most welcome and appreciated. TIA.
Old 01-15-2005
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
Reader's Digest version:
Yes you can network them together... But without knowing how you're currently getting on the Internet, whether you have Ethernet cards in your computers etc, I can't give you a step by step...
If you have DSL or Cable for Internet, get a broadband router and connect both computers to it... Even tho this will allow both computers to have Internet access, you don't have to excercise the option on the XP box... That also provides you with low level firewall protection.
If the PII is dialup only, you will need to make sure it has an Ethernet card installed ($20 - $30)... I'm assuming the XP box came standard with one, but if not, you will need one in each...
Then you get to decide about direct connect or hub, (different cables for each) and also TCP/IP configuration on them... Again, the XP will be simpler to config if you have never been introduced to networking protocols...
If you use any of the above terms in the store where you are getting your components, they will point you in the right direction, but they will also ask you various other questions about your wants and needs...
I would do some Google searches for simple home network setups so you can familiarize yourself with the architecture...
Hope this helps somewhat...
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
Old 01-15-2005
JMarcomb's Avatar
JMarcomb JMarcomb is offline
JMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond reputeJMarcomb has a reputation beyond repute
there are a fews ways... you could use a crossover cable to connect them.. or a hub if you have one sitting around... you could also use usb/firewire if you know what your doing
i use a wireless linksys router.. but your network is less complex that mine
yes ..you can network xp and 98 os's
you'll want to increase your memory in the PII computer if you want to upgrade to xp and also limit the # of processes/services that are running
viruses/spyware can crawl across the network into your recording computer.. so you want to be sure your internet computer is "clean" before you connect...
Old 01-15-2005
BentRabbit's Avatar
Drumb & Drumber
The only way a virus can infect a network resource is if it is designed to seek out network shares...
Since you are wanting to transfer files between the two systems (plug-ins, etc.) only create the share on the PII and it will be 'visible' to the XP box to download the files from...
If the XP box is not offering any resources out to the network, it will essentially be invisible to any malignant files that might end up on your 'public' box...
Security through obscurity you might say...
And what JMarcomb says is true... Make absolutely sure the files you bring in from the PII to the XP are clean when you transfer them...
I recommend keeping up to date viral protection on both systems... Since the XP box won't be going online, you will have to update the antivirus program manually... can be done, just not as automated...
Good luck!
Myspace Page
Old 01-15-2005
seryozha's Avatar
seryozha seryozha is offline
Dedicated Member
seryozha will become famous soon enough
Originally Posted by Cheeky Monkey
share one monitor.
You'll need a KVM switch for that, about $75.00 and the computers need to be close together.
You can, if you cant have them close together, buy a KVM switch that runs over CAT5 cable, so you can extend the distance up to 300ft. those are more expensive though.
If you have USB ports on both and they are close together, you can get a USB networking package that will basically connect the two computers via USB.
AD Baculum!
Old 01-15-2005
fldrummer fldrummer is offline
Force of Nature
fldrummer is on a distinguished road
If you don't need the internet on one why can't you just get a usb thumb drive then their's no hassle?
Old 01-15-2005
AGCurry AGCurry is offline
Force of Nature
AGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond reputeAGCurry has a reputation beyond repute
And, no you can't upgrade the PII to XP but you can upgrade it Win 2000 - just barely. Windows 2000 is a pretty robust OS (for Windows).
Old 01-15-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Or, if networked, you can run Remote Desktop or VNC to export your display to another box.
The fact that no one understands you doesn't mean you're an artist...
Old 01-15-2005
Force of Nature
Dont both computers need xp pro to remote desktop?
Old 01-15-2005
Flypaper for freaks
IIRC, you can get Remote Desktop for XP Home. I was not sure you can get it for Win 2k, which is why I recommended VNC
http://www.realvnc.com/
http://www.tightvnc.com/
However, a quick search (Google is your friend) indicates that Remote Desktop is freely available for any MS-supported Windows platform:
http://www.microsoft.com/windowsxp/d...dclientdl.mspx
Old 01-16-2005
EmmSee EmmSee is offline
Get DOWN for the UPSTROKE
EmmSee is on a distinguished road
Yup, Remote Desktop works on Win98, you just have to download the client. It doesn't come automatically installed like 2000/XP.
For a 2 PC setup, I'd just recommend a crossover cable for networking. Less wires, less money.
networking ( a little off topic) vigormusic Digital Recording & Computers 2 10-08-2004 21:10
networking copmuters, and a broken printer shackrock Digital Recording & Computers 4 12-22-2003 17:12
Networking of Musicians by State bdbdbucksKID Marketing Your Music / Publicity 13 12-15-2003 23:10
Need help on networking lap and desk jant Digital Recording & Computers 6 10-28-2001 07:43
